Gbc 32160 electric punch
How to change from 3 to 2 holes punched, or from 2 to 3 holes. when plugged in and turned on and both buttons are pushed in machine does nothing.
cTech1
  • 66 Answers
SOURCE: Panasonic Commercial Three Hole Punch BH 780
This inquiry needs to be directed at Panasonic's warrantee department in customer service :
Panasonic is available at the following contacts :
E-Mail :
Telephone:
1-800-211-PANA (7262)
Call Center operating hours:
Mon-Fri 9:00 AM - 9:00 PM EST
Sat-Sun 10:00 AM - 7:00 PM EST
Snail Mail:
Panasonic Corporation of North America
Consumer Affairs Division
Panazip 2F-3
One Panasonic Way
Secaucus, NJ 07094
Posted on May 17, 2008
  • 2072 Answers
SOURCE: Xerox hole punch -
Its become dull or developed burrs on the shaft, should be replaced.
Posted on Aug 05, 2008
  • 7 Answers
SOURCE: Broken electric 3-hole punch
There are two phillips screws in the bottom. Once they are removed, the top and bottom of the case are held together with clips molded into the case. Take a wide flat screwdriver and place it in the seam and gently pry it apart. Might want to start on the back in case you ****** up the plastic.
Posted on Oct 25, 2009
  • 32 Answers
SOURCE: Swingline Model 525 electric 3 hole punch
It has a safety switch. This switch turns machine on when it detects paper and off if it doesn't. Something wrong with sensor. Broken, paper stuck under it, out of position. Will have to open it up and check the sensor. ***Always remember to unplug any equipment before working on it***
Posted on May 09, 2010
Tally Girl
  • 1128 Answers
SOURCE: I have an Ibico ibimaster
First, clear the waste tray of all hole punchings under the machine, and check the holes where the punchings feed from for any blockages. The worst thing is the clear plastic pages you use for covers, these can block up the holes. So you may need to pick them out of the holes using tweezers.
Then try again. If you have to punch clear covers, then try to do them with just a few pages on both sides so that the plastic sheet isn't the first thing the blades hit.
Posted on May 23, 2011
Looking for a replacement cord for a sparco 96003 hole punch
Use any cord from something your throwing away that has a ground in the wire making it a 3 wire cord. White is common, black is power, and green is ground.
Nov 15, 2014 | Sparco High Volume Electric Three-Hole...
How to change a freeze plug behind the power steering pump on a 1994 s10 4.3
I would try to get a screwdriver thru the spokes of the pulley to punch a hole in the plug and pry it out. Then use a large punch to tap the new one in,,,if you have enough throw to hit the punch that is
Nov 02, 2014 | Cars & Trucks
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
My hole punch won't release the paper. I have to jiggle it before it finally releases.
You are stacking too many sheets of paper. Reduce the thickness of the stack. Think of all the time wasted while trying to the paper released. Sometimes the holes punched may be ripped.
Aug 22, 2013 | Sparco High Volume Electric Three-Hole...
Jammed the machine too many papers. how can i get it unjammed
Unplug the unit ! Remove the cover if possible then carefully use pliers or vise grips to turn the gears that drive the punch cam backwards to get the paper out.
Dec 17, 2010 | Gbc ® 24-Sheet 3230ST Electric Two- and...
Jan 22, 2009 | Office Equipment & Supplies
Replacing gear shift handle on column
under the cylnder is a very small hole. put the key in the switch and turn it until all the dash lights come on. then take a very still object like a small punch and push it in the small hole and pull out the ignition switch. sometimes u might have to hit the punch to push in the button.
Oct 18, 2008 | 1997 Ford F350 Crew Cab
156 people viewed this question
jasbo
jasbo
