Question about LG WD-1280FHD Front Load Washer
Error code f05 on a cda washing machine model c13401n. can you advise please
3 Suggested Answers
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
  • 16 Answers
SOURCE: LE error
try using a-fresh its should help you out.
Posted on Nov 03, 2008
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
Mar 06, 2013 | Hotpoint Washing Machines
Its dispalying error code F05
Code F05
Description:
Water temperature sensor error. If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component.
Hope this helps (remember to rate and lave a testimonila about this free answer).
Sep 30, 2011 | Washing Machines
Washer display code F05 what is this code?
the f5 error code is to do with the water inlet valve not working it will need replacing in the mean time try connecting the cold water to the hot select hot wash and see if the water flows into the machine
Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWOEAST912 - Error code F05
Well An F05 is a water temperature sensor error.
This occurs if there is a problem detected during the heating step of the wash cycle.
You will need to check the Water Temperature Sensor, Heating Element and the Heating Element Relay.
But as you says that your washer is only 4 months old so why don't you ask for warranty......
Please post comments if you need more help or information........
Good Luck!!
Thanks
Mar 02, 2010 | Whirlpool Washing Machines
F05 on screen
Hi. This is a water temperature sensor issue.
Replace any parts that is malfunctioning or defective.
Oct 04, 2009 | Washing Machines
I have a Kenmore Elite front loading machine machine HE3 that keeps giving me an error code of F05. What does this mean? Obviously I've lost the manual
"F05" is a heat sensor error code. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Actually, none of the error codes are included with your owner's manual. They are, however, included in the technical data sheet which should be located behind the lower kick panel directly below the door.
If you have any questions, please let me know. I hope this helps you.
Jul 11, 2009 | Kenmore Elite 45986 Front Load Washer
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
F05 error for Whirlpool GHW9100L Front Load Washer
The following link explains the "F05" error code:
I hope you find this information helpful. I have seen this error code generated by something as simple as a loose connector on the NTC sensor. Hopefully, you can resolve this with no expense. If you do require any parts, however, you can locate parts with illustrations at searspartsdirect.com or repairclinic.com. If you require further assistance, please let me know.
Sep 10, 2008 | Whirlpool GHW9100L Front Load Washer
ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Jun 12, 2008 | Washing Machines
LG WD-1280FHD Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
