Question about Husqvarna 21" Lawn Mower with Honda GCV160 Engine HVL 7021RH
Engine stops after startup. - Husqvarna 21" Lawn Mower with Honda GCV160 Engine HVL 7021RH
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
It's a good engine. Need more specifics.
It runs for 5 minutes?? it stalls as soon as it revs?
Did the problem just happen the week after mowing or has it been this way after the mower sat for months?
Posted on Jul 15, 2013
Why is there loss of brake pressure when engine is started and running?
That is a normal feeling created by two different operating systems. One system is the abs control unit and the brake vacuum booster is the other. As long as your pedal is firm before startup it means the system is functioning properly.
Oct 08, 2015 | Cars & Trucks
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
1997 Cadillac Seville Engine races 4000 RPM on startup
run fault codes and check for accelerator position sensor problem Check for MAP/MAF sensor faults.
Nov 17, 2013 | Cars & Trucks
Engine ticking on startup in 1998 gmc pickup
low on oil the first time now the valve lifters are worn
Apr 13, 2013 | 1998 GMC Sierra
Losing water. Engine sometimes missing on startup
have a pressure test done on your cooling system to look for leaks, you may have a bad head gasket that is leaking into the cylinders and going out the exhaust,hope this helps.
Jun 29, 2010 | 2005 Chevrolet Equinox
2003 Ford Escape won't idle on startup when engine is hot
hav car scanned for free at a parts place--that fan shud be fixed engine wont start cause a sensor keeps it that way from overheating--also certain modules age and become hot and need to cool to function--u may need a throttle body cleaning
Apr 20, 2010 | 2003 Ford Escape
Little power if you just get in and go. push on the gas and doesn't go. blows blue smoke if it doesn't run for a few days.
Hello Melissa,
Blue smoke is caused by burning oil. If you get blue smoke at startup or when taking off from a stop then you probably have leaky valve seals. The oil is getting past your seal and into the combustion chamber; When you startup the car the combustion chamber burns off the oil causing blue smoke.
You will definitely need to get this car to a shop, this will involve getting into the internal components of the engine.
Thanks for using Fixya! and Please rate my post:)
David R
Aug 15, 2009 | 1994 Volkswagen Jetta
I have a 2007 Hyundai Accent and white smoke at startup and now severe white smoke on occasion when driving. 16k miles, I drive about 600 miles a month.
White smoke during startup is indicative of a blown head gasket and/or cracked cylinder head..
Have the cylinders pressure tested to verify.
Do not use engine additives to try and stop the leak. They do not work.
Thanks for using FixYa - please accept this answer to remove it from the work queue.
Jul 15, 2009 | Hyundai Accent Cars & Trucks
My sound also crackles and I have a very slow windows startup
That's most likely a virus that's gotten into your sound device drivers. Try updating/reinstalling them. Try Dell's website or a search engine for exact drivers and how to install them.
Jul 13, 2009 | Dell Inspiron E1505 Notebook
Hpqste08.exe and hpqdstcp errors
try this click on the start button then type on the start search engine "msconfig" hit enter then click continue then click on the "startup bar" then click the disable all remember click the startup bar only ok then apply then ok
Apr 11, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Husqvarna 21" Lawn Mower with Honda GCV160 Engine HVL 7021RH Logo
104 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
