IBM WW1000 ribbon advance not working, I have checked the ribbon motor and ribbon feed follower + spring all seem OK, Is this a function board or anything I may be missing.
  • 3,594 Answers
Be sure the Ribbon lift/feed motor is plugged in, alittle WD 40 on thw upper and lower bearings, mark the gear that engages the ribbon and type to see if it moves if it moves ikt isn't fully engaging the ribbon this happens with some generic supplies.
DickyO
Posted on Jul 24, 2013
  • 3594 Answers
SOURCE: IBM Wheelwriter 6 ribbon not advancing
Befor you put a nrw motor in try a few drops of light oil on the m
motor bearings (WD40 works well).
DickyO
Posted on Mar 25, 2008
  • 3594 Answers
SOURCE: ibm ww1000 hammer solenoid is not working .lack of impression
The plastic cap on the silenoid plunger is probably broken, thet are availabe but a little rticky to install. We sell them for 15.00 including shipping.
Cleveland Business Machines
216-241-0027
Posted on Dec 10, 2008
  • 3594 Answers
SOURCE: IBM Selectric II Ribbon Not Advancing
First check to be sure that the ribbon is on the left of the shock wire where it comes out of the cassette, if that is OK then check the ribbon driver it should move freely and swing to the ribbon take up spool. Some WD40 will free it up. Also be sire the ribbon is winding in the direction of the arrows.
DickyO
Posted on Jun 16, 2009
  • 3594 Answers
SOURCE: ribbon won't advance on IBM Wheelwriter 3
Try some WD40 on the feed motor bearings top and bottom and the gear train it drives.
DickyO
Posted on Jun 19, 2009
unaasp192
  • 29 Answers
SOURCE: Ribbon will not advance
mark the ribbon where it turns, where there is a pin of the typewriter passing through the ribbon,mark it with a white marker.
and type something, if it doesnt turn, you know the machine has a problem.
or try everytime pressing on the ribbon, if it works you know the ribbon is coming up, check if the correction ribbon is placed good.behind the correctable ribbon.
unaasp192
Posted on Apr 12, 2010
Ribbon advance gear is stuck
On the R. hand side of the ribbon deck is the motor for ribbon feed, put som WD40 on the upper and lower bearings they do gum up and freeze the motor.
DickyO
Apr 09, 2014 | IBM Wheelwriter 3 Electric Typewriter Type...
IBM Wheelwriter 6 - Ribbon doesn't lift high enough for the key that's pressed to print on paper. Ribbon advances OK.
If theribbon dosen't lift at all see if the black gear on the R. side of the printer will move, if not w3iggle it and it should free up they get tooth for tooth with the motor gear. If it only lifts partually thereis an adjustment on the roll that works with the black gear. BE SURE TO CHECK THGAT BTHE PLATEN IS FULLY SEATED IN THE VSIDE FRAMES THEY DO GET LOOSE!
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
Found a new ribbon, put new batteries in the small compartment under type wheel housing. The ribbon won't advance. What am I missing?
The ribbon feed motors Gum up and don't move. Sprat some WD40 on the motor bearings. The motor is located just below the ribbon deck on the right.
DickyO
Feb 16, 2011 | IBM Wheelwriter 6 Typewriter
Ribbbon won't turn on IBM Electronic 50 typewriter.
I'm guessing you have a Wheelwriter not a memory writer 50..
Try a little WD40 on the ribbon feed motor and feed mech just under the R. rear of the ribbon deck. Also check the plug to that motor I have had them come out. If these don't work revove the ribbon, mark the black gear that feeds the ribbon with a dab of white out and see if it turns. If not you will need a tech.
DickyO
Feb 19, 2010 | Lexmark Wheelwriter 15 Series II...
My ribbon is not moving. I got a new ribbon, but it is still not advancing. Is there anything I can do. It is a IBM wheelright 6.
Try some WD40 on the upper and lower bearings of the ribbon feed motor. It's just under the R. front or the ribbon deck. also check to be sure the motor is pluged in.. Other than that you'll need a tech.
DickyO
Jan 19, 2010 | IBM Office Equipment & Supplies
The ribbon won't 'take up'. It seems stuck in one
Remove the ribbon and wind the feedwheel by hand and check for ribbon movement, if none, replace. Visually inspect the ribbbon feed assembly to see if it is rotating the feed gears (mark with felt pen) A drop or two of oil mayhhelp, but the ribbon motor may be defective also.
Nov 03, 2009 | IBM Office Equipment & Supplies
This machine gets used just a few times a year for straight typing. I was asked to replace the ribbon as the letters weren't appearing on the paper when the keys were pressed. No one knew when the last...
I'll assume this is an ibm ww. Just below the ribbon deck on the right is the ribbon feed motor try na little WD40 on the upper and lower bearings they do gum up also be sure the ribbon motor is plugged in.
DickyO
Oct 06, 2009 | IBM Office Equipment & Supplies
Ribbon won't advance on IBM Wheelwriter 3
DickyO
Jun 19, 2009 | IBM Wheelwriter 30 Typewriter
DickyO
Jun 15, 2009 | IBM Office Equipment & Supplies
DickyO
Mar 24, 2008 | IBM Wheelwriter 30 Typewriter
81 people viewed this question
jasbo
jasbo
