Question about Brother International HL-5470DW hl5470dw highspeed laser printer with
Reset HL5470dw drum - Brother International HL-5470DW hl5470dw highspeed laser printer with
    Problem Solver:
  • 17 Answers
You need to install a new drum and then reset the drum counter:
1.- Open front door
2.- Change the drum Unit
3.- Press Go button and keep pressing until the 4 lights turn on
4.- Release the button and close the door
Posted on Dec 02, 2013
How do I fix blurry print
Blurry prints can come from a couple of things. However with most issues relating to blurry prints on laser prints the following needs to be checked.
1) Is the paper damp - Try opening a new ream of paper and try printing to clear it.
2) Is the toner unit incorrectly installed or remanufactured with incorrect toner - Try replacing the toner cartridge.
3) Is the drum past it\'s use - If your machine has been reading drum near end or replace drum then it has reached or reaching maximum page count for the drum. Replace the Drum unit.
4) Are the reflecting mirrors dirty - Check inside the machine when you have the toner and drum unit out and see if you can see a narrow indentation above where the drum sits in the machine(Normally about 15cm long by about 8mm wide with rounded ends). Carefully clean this indentation with a lint free cloth.
Sep 05, 2014 | Brother HL5470DW - HL-5470DW Wireless...
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
6.Press Options.
To confirm you are installing a new drum, press 1.
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
How to connect brother hl5470 using wireless
Brother hl5470dw only requires a Wireless connection, SSID and password to connect up to a computer, not AOSS.
Read the network set up manual here
http://download.brother.com/welcome/doc002930/cv_hl5450dn_eng_net.pdf
Apr 09, 2014 | NetGear N750 Wireless Dual Band Gigabit...
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Office Equipment & Supplies
J2 drum cartridge light no after replacing drum
J2 is the indication that the Drum Cartridge life has elapsed. The possibly exists that the Customer has installed a New Drum Cartridge. The Customer would be directed to change their Drum Cartridge by their User Guide. This action on the part of the Customer will cause the Drum Reset Switch to actuate for a moment when the Side Door is closed. This is with the provision that the Drum Reset Circuit is working properly. That momentary actuation of the Drum Reset Switch, being actuated by the New Drum, resets the Drum Counter. Should something be faulty with either the reset mechanism on the New Drum Cartridge, or the Drum Cartridge reset Switch circuit, the Counter will not reset. Note: A new Drum Cartridge will NOT reset the Drum Counter unless the machine is holding a J2 presenton the display. The first revolution of the Drum will render the Drum Cartridge used. A Used Drum Cartridge will NOT be capable of resetting a J2. Again, one revolution of a new Drum Cartridge will render it to be a used Drum . Cause:
Apr 25, 2008 | Xerox WorkCentre XD130DF Laser Printer
Brother International HL-5470DW hl5470dw highspeed laser printer with Logo
174 people viewed this question
Top Brother International Office Equipment & Supplies Experts
k24674
Gil Shultz
Ron Baird
Are you a Brother International Office Equipment and Supply Expert? Answer questions, earn points and help others
