Question about First Alert SA302 Dual System Smoke Detector
Battery new bettery in. we have 3 alarms in our home only one goes off when we leave the house for several days. WHY
Changed battery in my 07 toyota tundra. when I connected the new battery, the alarm goes off. cannot get vehicle to crank or turn offthe alarm
You have upset the anti-theft system.
Disconnect the battery. Put a household bulb across the battery terminals for 3 minutes. Hold the battery leads together for 3 minutes. Leave the battery off for 1 hour. Put your key in the ignition, but not on. Connect the negative lead of the battery. Connect the positive lead in one go, bang and on. Leave the car for 15minutes to reset. Start the car normally.
Number 1 tip from a mechanic friend of mine. Maintain the power to the vehicle when changing batteries by using 2 lengths of wire or jump leads.
Jan 22, 2017 | Toyota Cars & Trucks
Alarm goes off installing battery in Nissan 350Z
Try leaving key in door or ignition turned on to shut down the alarm...
Jun 09, 2015 | 2005 Nissan 350Z
How to disconnect the alarm system .
just cut the red wire and isolate him
Nov 20, 2014 | 1994 Mazda 929
My 1999 jeep wrangler alarm(avital) goes off and
try resetting alarm lower drivers side window and take out keys,disconnect battery and fully charge it , when you reconnect battery alarm will go off ,put key in drivers side door and turn key all the way open and all the locked 3 times then remove key that should reset alarm.
Oct 08, 2014 | Cars & Trucks
Battery low sensor failure on Wireless Simon ADT
the sensor seems to be malifunctioning and will have to be replaced
Sep 20, 2009 | GE Security Simon 3 Wireless Home Security...
Antitheft alarm on our 2001 mercury sable goes off on its own
Get a new car! JK - my 2002 Sable does the same thing. It can be 5 times a day then not for a month, or 2-3 times a day for a week straight. It happens in different locations and different weather and different times of the day. To my knowledge has never done it in my garage at home.
I have not called a dealer. Has anybody ever found the real problem? Could it be in the remote itself? I tried leaving it unlocked at work, but yesterday it went off just as I was reaching toward the door handle.
Aug 28, 2009 | 2001 Mercury Sable
Can't Change Code on MOD600 Alarm
Hi Michael, we have a MOD600 in our home also & need to reset the whole system - did you end up finding anything useful?
Apr 26, 2009 | Computers & Internet
Program
On Simon panels, the master code should default to 1234 if it's been powered down for several hours (I can't remember how long, at least four hours, possibly 12-16). So, unplug it from the wall and disconnect the system battery and leave it for the night. Power it up by plugging in the battery first and plug it into the wall. Then enter the code as 1234. It should annouce that the alarm system is disarmed. If so, your code is 1234. ;)
When removing the battery, be very careful to not break the little tab that holds it shut! Can't stress that enough.
Oct 19, 2008 | GE Security Simon 3 Wireless Home Security...
First Alert SA302 Dual System Smoke Detector Logo
41 people viewed this question
Top First Alert Home Experts
JOHN LAPIER
Dan Apthorp
Are you a First Alert Home Expert? Answer questions, earn points and help others
