Question about Cameras
Does camera have timer - Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Some do, some don't. Do you have a particular make and model in mind?
Posted on Jul 15, 2013
How do I use the self timer on my Pentax K-x?
You aren't supposed to leave the timer cocked for long periods, probably because it could wear out the timer spring (similar to the reason you aren't supposed to store the camera for long priods with the shutter cocked).
I thought that you set the timer by rotating the timer lever 90 degrees or more counter clockwise (when looking at the front of the camera). The further you rotate the timer, the longer it will run. Moving the timer lever exposes the start lever underneath the timer. Pulling the timer lever counter clockwise (it starts out pointed straight up) will start the timer, and putting the start lever back in it's original position will stop the timer.
Once the timer is stopped it is possible to take a picture by releasing the shutter normally, the timer can be restarted, or the timer can be reset for a longer time. After the timer is stopped it should be restarted and allowed to count down to zero before the camera is stored. I'm almost certain that the timer can only fire the camera if the shutter is already cocked, so it is safe to release the timer and let it run down any time that the camera is not cocked.
Good luck and do rate the solution if helped
Nov 27, 2010 | Pentax Cameras
How do I use the timer on my camera?
Select the timer mode (left arrow on the 4-curser-button). There are 3 settings in the order of 10sec timer; 2sec timer and timer off. Select either the 10 second timer (if you want to be in the picture) or the 2 second timer (more appropriate for long exposures when camera is on a tripod or similar to avoid camera shake when pressing the shutter button), then press the shutter button fully. The subject will then be automatically focused just before the picture is taken. There's a little light on the front of the camera (top right hand corner when you look at the camera) which should blink when self timer is activated. Pressing the menu button while timer is activated will cancel self timer mode.
In low light conditions this light may turn on brightly to double up as an AF assist light.
Hope that helps
Jul 24, 2010 | Panasonic Lumix DMC-FX9 Digital Camera
Is there a self timer on Samsung s73 camera?
Sam sung s73 camera has a seif timer. which is at the top level controls of your camera.with a clock symbol on the external button,if the button is pushed the the self timer will activate.
Feb 16, 2010 | Samsung Digimax S730 Digital Camera
I cant figure out how to set the self timer on this camera
If you press the left < button on the camera before you take a picture you will have the option to set the self-timer. The options that you can choose are: 1. Single shot; 2. Continuous shot; 3. Self-timer (10 sec) / Remote control; 4. Self-timer (2 sec); 5. Self-timer (10 sec): Continuous (2 - 10 shots).
Hope this helps!
Please rate!!
Cheers
Oct 01, 2009 | Canon EOS Rebel XSi Digital Camera
How do you find the self timer on a s630 camera?
Press right on the multiselector (marked with a one-handed clock) to cycle through the self-timer modes. Once you have the self-timer set, you start it by pressing the shutter-release button.
Aug 24, 2009 | Samsung Digimax S630 Digital Camera
Self timer set up
1. Secure the camera to a tripod or place it on a stable surface.
2. Rotate the mode dial to [S], [P], [PICT], [AV], or [M]
3. Press the Power button turn on the Camera.
4. Press arrow [>] .
5. Use up arrow or down arrow to select the desired self-timer mode.
6. Compose your scene and press the shutter button.
  • The self-timer function is activated.
  • The photograph is then taken after the preset time.
  • To cancel the self-timer at any time, press the shutter button.
After one shot is taken, the self-timer mode is turned off.
If you wish to take another image using the self-timer, repeat these steps.
Mar 19, 2009 | Pentax Optio 60 Digital Camera
Set the timer
  1. Place your camera on a tripod and prepare your scene.
  2. While in a shooting mode, press the timer button (the bottom button in the circle set on of the back of the camera). Press it repeatedly. It will cycle through self-timer and remote-control. On the screen, a Timer will appear for the self-timer and a little Remote with a lightning bolt will appear for the remote-control. Stop pressing the button when the timer appears, pause for 3 seconds to allow the camera to confirm the setting the icon will disappear.
  3. These instructions are described on Pg 55 of the manual, but I will repeat them in simplified form in case you don't have the manual.
  4. Once the timer setting is set, press the shutter-release button fully. If you press it half-way it will focus and lock the exposure, then press it fully.
  5. The self timer/remote control lamp will light for 10 seconds. Get in position in the scene, after the 10 seconds the light will begin blinking. After 2 more seconds, the picture is taken.
  6. To cancel the timer mode, press the Timer button again; however the timer mode is automatically canceled after one shot.
It is important in all timer scene shots with cameras, don't stand directly in front of the camera because this will then focus on you instead of the scene.
Jan 21, 2009 | Olympus ? Stylus 500 Digital Camera
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
Self Timer Operation
Easy, in camera mode, push the menu/ok button, use the left and right arrows to display the self timer mode. There are only 3 options on the menu. (self timer,cont,option). Once self timer is on the screen, use the up arrow to pick a short or long self timer.
Once it is set, compose your picture and press the release button as normal, the self timer will do the rest
Jul 27, 2008 | Fuji FinePix E500 Digital Camera
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
