Question about RCA RTD317W Theater System
Won't Play DVD
Have had the DVD Player for a year or so. Has worked fine the whole time. Went to use it the other day. I put the disk in, it starts spinning like it wants to load but instead of playing it shows a TT on the display screen and start a timer. Nothing changes the screen. Took out the DVD, put a different one in and it did the same thing. My TV screen also now goes to a blue screen and says "no signal". Any suggestions. I have changed nothing so not sure why it's doing this now.
SOURCE: RCA RTD210
I had a similar problem some time ago. In a hurry, I placed a DVD in the tray; and didn't notice that the DVD was not fully inside the tray (inside the insert of the tray). So the DVD got stuck; the only way to remove it was to open the RT210 by removing the screws located at the back of the unit.
Posted on Sep 07, 2007
zaids
  • 456 Answers
SOURCE: Will play rental dvd's but won't play store bought dvd's
complicated
Posted on Dec 20, 2007
bstimpy
  • 47 Answers
SOURCE: rtd207
There may be something blocking the path of the dvd drawer. Take a peek inside. You might also try very gently shaking the machine. Do you have kids who might have shoved something in there?
Posted on Mar 19, 2008
SOURCE: no power?
i just picked up this same unit model and 1 thing is your backwards on the LED on/off...its blue when its off, and LED goes off when turned on.
Hopefully this will help determine if its off or on
RandyMan
**Life isn't about waiting for the storm to pass...its learing to dance in the rain!!
Posted on Jul 06, 2010
  • 10 Answers
SOURCE: DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Posted on Jul 10, 2010
My dvd won't play. every dvd i put in, it says bad disc. the vcr works fine. is it time for a new system. i tried a head cleaner and it says bad disc
Not necessarily time for a new one. I would give the DVD player a good cleaning before you consider a new unit. A good cleaning disk with some little bristles on it. Run it through three full times. DVD players are far more sensitive than VCRs and have to be cleaned even two weeks or so. When they get real dirty it can take some fooling with to get the DVD player to even accept the cleaning disk. But if it just won't accept the cleaning disk and you can't watch a DVD in it then it's time for a new one. I had a DVD player one time that took an hour of fooling around with before it got cleaned good enough to play DVDs. Worked for a couple years afterward.
Regards, Tony
Apr 19, 2011 | GoVideo Go Video DVD/VCR Combo
DVD won't play
Netflix doesn't know what they're talking about. I looked it up - your DVD player doesn't have an autoplay feature. Can you try the DVD on another DVD player. Computers DVD drives generally read them differently - and decode them differently, than a regular DVD player. Also, if your DVD drive is a writable drive, it will have a stronger laser than your DVD player. I think it's likely the disk is damaged, slightly. If you cleaned your DVD's laser, it might be able to read it well enough to play - or it might not. I started having problems like this with a few of my own DVDs before my DVD player's laser went out. Basically it's a combination of laser quality and disc quality. If it remains just this one disk, I'd suggest leaving it alone. But if you start running into this problem on other disks as well, you'll probably want to have the laser replaced in your DVD player.
Aug 14, 2007 | Amphion Mediaworks S99 DVD Player
The screen goes black every few seconds while playing a dvd. I've tried cleaning the player already and still have the same problem.
I am having a similar problem with mine... same model. It worked fine last night but this morning, went on the fritz. It started pausing every few seconds and so we took the DVD out. This evening, I tried to play a number of different DVDs but now the player will not even read any of the disks. I've had this DVD player for about 6 years so maybe it is just time for something new!?
Dec 07, 2010 | Toshiba SD-K620 DVD Player
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
DVD Drive disappeared
you are probably running xp go to help and type in find new hardware sounds like somehow your drive got deleted in the hardware and device manager this will work with vista too unless the drive went bad naturally
Sep 28, 2009 | Acer Extensa 5420-5687 Notebook
Blu-ray discs all of the sudden incompatible and won't play
Look for a firmware upgrade for your player. They exist for sole purpose of increasing compatibility with newer blu ray releases. If that does not do the trick it appears that your player's laser assembly is losing its ability to focus on the disk(s). Repair is not cost effective and you will have to go shopping.
Mar 31, 2017 | Sharp AQUOS Blu-ray Disc Player
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
I purchased a new Zenith Tv and have hooked up my dvd player which is about four years old (Toshiba). The connections are all right but when I put in any disk (I have tried many) it registers no disk so...
try to use player on old tv again does it still work 4 yrs old dvd player is to old for new days dvs on new tv u def wann upgrade to 108p upscaling player samsung makes with hdmi cable to new tv flat screen or reg coneection will look 10 times better also older toshibia cant play read new dvds its terrible
Oct 07, 2008 | Televison & Video
Wont play dvd
Try to reset the settings in the setup to default, try to burn an other DVD, it might work.
Mar 13, 2007 | Yamada DVD-5520 DVD Player
RCA RTD317W Theater System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
