Question about Lanier Advocate V System LCR - 5 Conference Recorder Transcriber
No Power We lost power to the building and now I can't get power back to my recorder
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
Apr 08, 2013 | Audio Players & Recorders
Sony RDR-HDC100 will not remain operating and turns itself off
follow this step:
No power
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
Screen is "frozen" or completely black, or Power button does not work
  1. Try turning the power off and wait 3 seconds before turning it on again.
  2. Make sure the TV and VCR (if connected) are set to the correct channel or line.
    However the power supply can be faulty,some resistor,capacitor, diode or IC . see the block attached .If you do not have skill for electronic, go to the repair shop.
    God bless you
Feb 09, 2013 | Televison & Video
500gb playback
Have you tried resetting it? Use master reset to bring factory default settings.
Car Performance Chip
Aug 17, 2012 | Sony Televison & Video
Rebuilt transmission with 800 miles lost power
Lost power to what
Usually when a transaxle is removed &
reinstalled, it is common, sadly I say ,that
things are not put back as they came apart
Having once owned a trans shop I hate to
remember those days.
The folks that work for you seem to leave off
or leave loose lots of wire harnesses & especially
ground wires
Don't know if that even applies to your case
as lost power is no help at all in helping you
Sorry, We need lots of info & then only guess
Aug 03, 2012 | 2000 Ford Taurus
Magnavox h2160mw9 power won't come on
I have 2 Magnavox h2160mw9 that won't turn on after power failure. I unplug, wait 15 to 30 minutes, then re-plug and the Magnavox h2160mw9 powers on by its self. I have to reset clock and any programing that was erased. Channels previously scanned remain okay. Hope this helps.
Jul 07, 2012 | Magnavox H2160MW9 HDD Recorder
I don't have power going to my AC. The diagram was lost. I need to know where the fuse is for it.
The circuit is on a 25 amp fuse in the power box under the hood. A brown wire goes from the fuse to the a/c relay. I would look at all of the 25 amp fuses. Most should be 15 or 20 amp.
Jun 23, 2012 | 1990 Chevrolet C1500
Pioneer VSX-519V Multi-channel receiver won't turn on.
You could have blown the fuse in the unit, or worse still blown the output device(s) in the power amp.
Dec 30, 2017 | Pioneer Audio Players & Recorders
My woofer is 18' 600w rms power. so what is the
Basically you cannot break you woofer with too powerful amp, but you can break it using too weak amp. This is because if you don't have enough watts going to you woofer the cones movement isn't controlled properly. I'm usually using +20% to the woofers RMS and peak power. This will also make the amp last longer because you won't use it at it's peak performance all the time. If possible use manufacturer whose prising policy matches your woofers manufacturers, that way you won't end up with "2000w peak power" cheap amp with real output of 30w. and in the other end cheap woofer won't handle expensive amp with real 600w rms so well, you need to find a midlle way here. Hard to say without knowing the make and model of the woofer.
This is a taste question for some people, and I haven't build a system to match so powerful woofer ever in my life. But I'm pretty sure you won't go wrong with this one.
May 20, 2011 | Audio Players & Recorders
Buying a used Tascam 788. P.O. lost the power supply. How can I get a replacement? Couldn't find anything on TASCAM site.
Hi, Provided there is a tag on the back showing the units model number, on that same tag should be the power requirements for it-buying a universal power supply, or even a used working one to another piece of equipment is acceptable as long as the polarity is the same. Polarity is located right next to where the power supply plugs into the unit. It will be a " circle with a dash inside it with a line connecting to a C looking symbol with a line coming out of it connecting another circle with a plus sign inside. " that is a typical outer ground/inner positive marking. a power supply will be marked the same. If they match the polarities are the same. Next make sure the power supply says the proper DC voltage and Milliamps or amps-Ma/A example: 2400Ma, 2.4a. I hope this helps and thank you for asking FixYa, good luck and don't forget to write back and let me know how I did, Prodzilla.
Apr 23, 2011 | Record Tools Tascam Dp02 8 Track Digital...
Lanier Advocate V System LCR - 5 Conference Recorder Transcriber Logo
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
