Washing machine the washing machine is working fine apart from the drying cycle wich fills with water while in the drying cycle any ideas ? any way of resetting the cycle ?
  • 1 more comment
  • pvp803 Dec 02, 2007
    i have the same problem... during the dryer cycle it sounds like the machine is drawing in water; it never fills, but never dries since just enough water is in the basket.
    i turn off the cold water supply during the dry cycle, however i think this maybe bad because i swear i smell something burning.
  • Anonymous Apr 02, 2008
    My washer/dryer unit is not functioning properly. The dryer is not drying the clothes. It seems to be adding water during that cycle.
  • Anonymous Sep 23, 2008
    i had the same prob with mine i found it was the pipe that gos under sink was rong way up
I think the automatic water valve is not doing its job, may be blocked or just broken.
I have the same problem, & am going to remove it tonight to clean it out......
Posted on Oct 01, 2008
  • 164 Answers
There could be several causes for this. he timer could be faulty and is calling for water in all cycles or you might have a bad pressure switch, which controls the water flow.
Posted on Aug 28, 2007
SOURCE:
Hotpoint WDL520P Washer dryer Filling up with water as it should during the drying phase untill the end of the cycle when it fills up entire drum with water constantly during this cycle it is constant
The other logical point is that it can be related to a faulty output or error from the program controller output. In some cases choosing an alternate program cycle can confirm this case of faulty cycle patterns.
Feb 12, 2013 | Washing Machines
Roper washer fills and washes then will not fill on rinse cycle but goes into washing dry
Run the machine with hot only, and then cold only. Post back your results.
Nov 11, 2012 | Roper Washing Machines
I have a kitchenaid dishwasher modl # KUDIO01IL. Someone opened the door during a wash cycle and now the CLEAN LED is flashing. Tried pushing cancel and unplugging. No change. Any ideas/
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn't work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Nov 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
The machine fills with water during drying cycle and does not fill for the wash cycle
First, did you know that this machine steam dries clothes? The first thing it does on the dry cycle is to wet the clothes which it then heats to dry with condensation. There are better answers regarding this feature on fixya. But assuming that the dry cycle is working as well as it ever does, it appears that your wash cycle is not functioning properly. I would need more info to figure out why it is not filling with water / working at all.
Mar 31, 2010 | Malber WD1000 Front Load Washer/Dryer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Slow rinse cycle fill
take the hose off the cold water valve and check the screen on the water valve ,make sure the cold water is on all the way and the hoses are on the right valves get a water bucket hold the cold water line in it open the cold water valve to check the pressure
Jan 30, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
99 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
