Question about Refrigerators
Model number phs69ehss3 code 4 - Refrigerators
Need the code 4 a samsung tv. Model number ..un4dc5oooqf...so i can program my lax max new generation univeral remote model number li-z414 please.
Your remote should of come with a document which would of had the codes for the TV you use, if not you can download the codes by typing Samsung and model number for the universal remote model in google. You should get some responses.
Jun 28, 2015 | Samsung Televison & Video
I dont know how to enter my code numbers into my
Not certain for your particular model, but to enter the 4 digit code on mine it is as follows:
At the code prompt press button 1 the required number of times for the first number. Button 2 for the required number of times etc....
For example: code is 9876
Press button 1 nine times
Press button 2 eight times
Press button 3 seven times
Press button 4 six times
Sep 18, 2014 | Car Audio & Video
Need the code for mobis hm 3700
I have a Kia Carnival 2005 KVII. I had to contact Kia to get the radio code and give the vin number. Note # you will only get 3 attempts.
My Kia has a Mobis HM3700 and the Code I was given is 1812.
To insert code:
1 look at the front of the Radio you will see a screen, and at the bottom of the Right hand side is a set of channel select buttons.
they look like this
1 2 3
4 5 6
Each button from button number 1 to number 4 will cycle through from 1, 2, 3, 4, 5, 6, 7, 8, 9, to 0 each time you press these buttons you will change the number on the screen.
When you have the numbers shown below
Button numbers 1 2 3 4
Numbers showing 1 8 1 2
Than press Number 5 button to accept
Jan 23, 2014 | Kia Cars & Trucks
Need Source Dode for an RCA TV model DETK185R.
The RCA DETK185R TV can be controlled with Universal Remote Controls. I tested several.
The best match was a 4 digit universal remote from GE. Model Number 10841. Code 1961 worked almost everything.
With a 5 digit remote from RCA, model number RCRN04GR, Code 12372 worked Power, Channel, Volume and Input.
A 3 digit remote from GE, model RC24912-B. Code 166 was able to control Power, Channel, Volume and Input.
An old 3 digit remote from RCA, model RCU-403A. Code 062 was able to control Power, Channel and Volume.
Most remotes from GE and RCA will use the same code numbers. So even if you have a different model remote from GE or RCA, these codes may work.
These codes should work with other TV models in this series from RCA, including Detk215r, Detk186r and Detk156r.
Apr 15, 2013 | RCA Detk185r 18.5" Led Hdtv
4 red flashing lights on power button
That is an error code and what it is depends on the brand and model number---most sets list the error codes in the owner manual but some do not.
GOOGLE is a good source of information---Google the model number and "error codes" or "4 blinks"
Mar 31, 2012 | Televison & Video
Frigidaire model phs69ehss3 already change the control board, timer freezer is working fine but the refrigerator is to cold set at 34 derees reading 8 degrees
you have a damper in the fridge side,when it reaches the temp. that you set it for the damper door should close but it sounds like yours isn't.here's a video to watch it should help you out because you said you already changed out the board.....http://www.repairclinic.com/PartDetail/Damper-Control-Assembly/1194800#repairHelpVideoTabs......copy and paste.
May 05, 2011 | Refrigerators
Someone gave me a Philips TV, but it doesn't have a remote. I have the serial and model number. They are 94492161serial #, model # is PL7125C107. Is it possible to purchase a remote for it?
Hello
Just buy one PHILIPS UNIVERSAL REMOTE CONTROL MODEL NUMBER [CL 034]. Philips is listed in its codes. Serial number and model number isn't mind. There are so manu codes for you to set it up. Code for philips listed is :
........... 0807 0022 0020 0422
................. 0122 0222 0322 0002 0520
....... 0919 0521 0621 0430 0247 0901
....... 0402 0408 0109 0210 0310 0715
You will get its catelogue and user manual with details along with that device.
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 24, 2011 | Philips Televison & Video
Need code number
Based on the model number and type of remote control being used you can locate the code numbers for Sharp televisions. If you have tried all of those that came with the remote you can look up additional 3 or 4 digit codes (depends on whether or not the remote utilizes 3 or 4 digit codes) online.
Dec 04, 2010 | Sharp Aquos LC-C3234U 32 in. LCD TV
I need the code 4 a phillips HTS3410D dvd home
I don't think the codes are given by model number but you can access one for all's website directly and obtain the code list for your urc device, the link is: http://www.oneforall.com/support/manual , you will need the remote control model number.
Feb 19, 2010 | Televison & Video
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
