Question about Toro 74360 Zero Turn Rider Lawn Mower
Toro Z4200 Moderl 74360
It is nearly impossible to make right turns and the arm is hard to push forward and pull back for reverse
wadembly
  • 489 Answers
SOURCE: I have a toro self propelled lawnmower. Ireplaced
the spider gears are in on the wrong side more less like you put the rear end in backwards
Posted on Nov 10, 2009
barterjoe
  • 338 Answers
SOURCE: My Toro Z4200 will not
Make sure the hydraulic transport bypass is not open. It may be that your belt idler is sticking for the drive system. Check under the machine and see if all the belts are tight. You might need to grease the idler arms.
See a local dealer like www.arcolawn.com for diagrams and parts.
Good luck
Posted on Mar 28, 2011
SOURCE: what is wrong with the toro push mower pull cord if it will not pull out?
I would say check the bolts that hold down the pull cord they are the same thread as the cover bolts but the cover bolts are a tad longer and if used on the pull cord housing they stick down to far and hit the fan blades on the magneto and it will not rotate
Posted on Mar 27, 2012
SOURCE: I have a toro (20074) lawn mower that is hard to
Drive unit bad. Toro didn't design it very well
to much to repair, all used have same problem. I'm buying a Honda
Posted on May 06, 2012
roberthig924
  • 30 Answers
SOURCE: toro z4200 hard to turn, release levers are ok, pump is making winding noise
Check your fluid..... Sounds low...
Posted on Sep 16, 2012
I have a toro zero turn z4200 starts and runs fine but when I put arms in gear, it will not move forward or backward.
Make sure the drives are engaged. Under the seat and towards the rear are two thin metal levers with finger loops. These are used to disengage the drives in order to push the mower when the engine is off. Levers towards the back to engage.
Good luck
Mar 30, 2015 | Toro Garden
Why won,t my toro z4200 zero turn mower go forward or back model#74360
Hi there, I assume the motor runs as usual, and doesn't cut out when you try to move forward or back. That would be a different problem than what I'm thinking about now:
If you look underneath at the transmission belt (this usually goes from the motor pulley to the rear transmission / diff) and see if it has fallen off a pulley, or disappeared completely. This would stop the forward or reverse drive of the mower. If this is the case, a new belt should solve your problem.
Jun 12, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro Z4200 hdro won't stay in neutral
Your throttle csble is stretched it needs a new one
Dec 15, 2013 | Toro Garden
Slow speed on one side.
Check to be sure there is not a lot of grass and debris packed in spaces that prevent proper movement of the control arms.
If the control arms have free range of motion then you will need to check your fluid level and purge the pumps.
To purge the pumps jack the unit up and place on jack stands so that the drive wheels are off the ground. Release the transmissions so that they are in freewheel. Start the unit, release the brake and work the control levers slowly to full forward then full reverse 6 times. Shut the motor off, lock the transmissions back into drive. Start the unit and work the control levers back and forth 6 times again. Take down off the jacks and check fluid level. If there were any air pockets in the pumps this procedure would have purged the air out.
Oct 01, 2012 | Toro Garden
I have a Toro Z4200 series and it has probably close to the 2000 hours on it but the engine has been replaced 2 times and now the left side steering just all of a sudden cut its speed in half... I need...
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems.
Oct 01, 2012 | Cars & Trucks
MOWER WILL NOT MOVE
check the belts then make sure the levers you pull to be able to push it around are released
Apr 04, 2012 | Toro 74360 Zero Turn Rider Lawn Mower
My Toro Z4200 will not turn when i engage gear on my right hand, machine sat all winter in my garage, replaced battery, which i can understand, but why did the hydro-gear on right side quit working just...
Good luck
Mar 13, 2011 | Toro Lawn Mower With Toro Power Tools
Toro 74360 Zero Turn Rider Lawn Mower Logo
27 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
