Question about Garden
155c john deere lawn tractor
I have a john deere lawn tractor 155c that won't start, the battery is good ,oil level fine,gas is working,blades not engaged,what else could it be
  • 356 Answers
Take the spark plug out and see what it looks like. If it's dark, sooty or wet smelling like gas, then you have a spark problem. Might need new plugs, a new coil or charging the battery up.
If the spark plug is dry and is a light tannish, brownish color than your problem is not getting gas. If that's the case, take off the fuel supply line to make sure you have gas to the carb. If that is fine, then you might need to take the carb a part to make sure you don't have plugged jets or passageways in the carb itself. If you want to find out quick, you can squirt a little gas into the carb intake and see if the the engine pops off. That will tell you as well.
Good luck
Posted on Jul 15, 2013
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
  • 218 Answers
SOURCE: blade position for 155c john deere
Hi..my name is Keith...to answer your question..there is no certain position to put the blades and there is enough clearance that they wont hit...but there is a proper torque on the nut when reinstalling the blade..and its usually like 100 foot pounds..i hope this has helped
Posted on Jun 30, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Posted on Jan 08, 2010
wadembly
  • 448 Answers
SOURCE: The mower blades on my John Deere stx 38 lawn
it sounds like the safety switch under seat is bad
Posted on Jun 28, 2010
125 electrical drawings
Here's the link and I'm sure you will get the solution of your problem.
John Deere 102 115 125 135 145 155C 190C Lawn Garden Tractor Technical...
Sep 14, 2016 | John Deere Garden
My john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Aug 15, 2012 | John Deere Garden
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
Bought a used John Deere lawn tractor. Used it 3 times and today it won't start. Checked battery and date Oct. 2008. Bought and installed new battery. Insert key, step on clutch and "nothing"...
hi,
one of the safety switches probably came out of alignment, probably the safety switch at the pto blade control. its an electric switch up under the frame usually. there are a few of these switches on riding mowers and just one of them will stop it. check your seat switch to make sure its functioning. a word of advice. these switches are backwards of what you would think they would be, meaning when the switch contacts are apart, it will start and when they are closed or together it wont. if switch seems to be working unplug the electrical connector off the ignition switch from the rear and see if its rusty, plug it back in. check your battery connections for rust, check all your contacts for rust and sand them down.
jm .
May 17, 2011 | John Deere Garden
Blade position for 155c john deere
Apr 11, 2009 | Garden
Garden Logo
229 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
