Question about Dishwashers
Ariston li 661
My Ariston LI 661 A does leave water behind and do not finish the work. The light number 4 and 5 starts flashing. What is the problem and how to solve it?
4 Suggested Answers
  • 190 Answers
SOURCE: My Ariston LI 700 I dishwasher doesn't complete wash cycle
dear customer,
 we recommend u to perform the following checks on ur dishwasher,
  1. Test the timer motor
  2. Test the thermostat
  3. Test the heating element
for more details for self test instructions try the link http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
Plz rate this solution.. thank you..
Posted on Apr 08, 2009
SOURCE: Ariston LI 45 door will not remain closed and will
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
Posted on Jan 02, 2011
Daniel S
  • 4323 Answers
SOURCE: hello, i have an Ariston LI
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Posted on Aug 15, 2011
Ariston li 680 duo
Please check for debris in the motor/pump assy. Simply remove the bottom dishrack and the the filter cover.
Mar 12, 2014 | Dishwashers
I have an Ariston LI 670 B-S-W. first, I was told this was a Bosch product, and second, I was told I could swap out a custom panel on the front, or purchase a stainless steel door to swap out with the...
True and True - compare the pics of the interiors on the shopping websitses, so see which Bosch model matches (baskets/shelves may be different) but why not keep it as is? Any work to change it could go wrong. Leave working kit alone.
Dec 15, 2013 | Hotpoint-Ariston LI 670 Builtin Dishwasher
I have an Ariston 640 LI dishwasher and no water seems to be flowing into the dishwasher
hi there Mellisa, Is the tap turned on? if it is in may be the inlet valve at fault you will need to have it checked it see if the valve is recieving the open command from the controler. let me know if this helps, regards
Gary
Oct 16, 2011 | Ariston Technologies LI640S Dishwasher
Jan 31, 2010 | Ariston Technologies Dishwashers
dear customer,
Apr 08, 2009 | Dishwashers
Need to find parts dealer for Ariston dishwasher
Please let me know where I can order replacement part for LI 700-NA I need a water valve, serial number of that part 409245172. Thank you
Feb 02, 2009 | Ariston Technologies Dishwashers
Ariston Dishwasher LI 675 DUO
1) Ensure the dishwasher is turned off.
2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher)
3) Pour powder indo the dishwasher
4) Turn the dishwasher controller to the top position (the 12 o’clock position) – this is the eco-setting.
5) Press the on/power button on the dishwasher, so that it now turned on (a light will display)
6) Move the dishwasher controller to the “R” position (it’s on the very left), and leave it there a second or two.
7) Move the dishwasher controller back to the eco-setting (the 12 o’clock position
Sep 16, 2008 | Ariston Technologies LI640S Dishwasher
Stars cycle thin stops lights reg and eco start blinking
Clean out the filter really well, then replace it. This should reset the dishwasher. If it does it again when you try to run the dishwasher. Take the filter out and re-seat it. Some times it's not sitting exactly right. Good luck and I hope that helps.
Mar 04, 2008 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
