Question about Bosch WFMC 3200 Front Load Washer
Washer wont drain or spin
My bosch front load washer 3200 series will not spin, the water sits in the tub. I pulled the back off and the belt was not broken but there is no action when it comes to spinning
  • 19 Answers
As long as the water is draining away okay,then it sounds like new carbon brushes for the motor are needed if belt is ok.Should cost 10 pounds or so for replacement.Turn off power via socket before removing belt and motor.Good luck...
Posted on Aug 28, 2007
  • Skaman123 Aug 28, 2007
    P.S If it isnt draining or spinning (but the drum still turns while washing),ignore the last solution and check for blockage in hoses to pump or in the pump itself.If the washer does not drain it will not spin anyway,for obvious safety reasons.Lets know how u get on.
Drum wont turn
hi take the back off the washer the belt might have snapped if the belt is ok the other fault could be the brushes on the motor 2 black plastic blocks sit either sid e of the motor these are made of carbon and wear down can stop the motor working hope it helps
regards
shaun
Nov 23, 2011 | Bosch WFMC 3200 Front Load Washer
My bosche mod # wfmc1001uc wont spin with clothes in it.
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 10, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
It won't drain and spin
if the drain tube from the washer to the pump and the pump to the house drain is plugged or kinked,and the water can't drain the pump will have back pressure and the e.c,u, will shut off the pump, if the water can't drain then it will not go into spin,also check the pump for blockage or a broken impeller
May 11, 2010 | Bosch WFMC 3200 Front Load Washer
My bosch classix 1200 fl wont spin or drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Oct 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I have a top loading kenmore 70 series washer. It
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine does not spin
Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
It will not agitate or spin.
needs new bushes to electric motor common fault when the bushes wear down it cuts power to machine this will stop washer from washing and spinning
Jan 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Water wont drain
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
**Take the front cover off and you will find brake pad pieces in the bottom.
Now some say you have to pull the center out to replace the pads...I don't. Here's how I do it..
Remove old screws were brake pads use to be and loose them! Kits comes with new screws that you must use. The transmission will turn free without the brake pads. You will need a 3/8 stubby ratchet. Insert 0ne pad in place toward the front and line up holes with front set of holes in mounting plate. NOW....spin trans around until the pad is near the back set of mounting holes. I use an Allen key to align holes and put rear screws in. Once you get the back one in the 2 front ones are easy. Don't forget to bring a new belt with you!!!!!!!!!!!!
NOTE:.....You must coat the new brake pads with a little silicone grease**
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Dec 20, 2008 | Amana NAV5800A Top Load Washer
Bosch WFMC 3200 Front Load will not pump water out
the pump gears could be stripped or clogged with soap residue including the line from the pump to include the drain hose itself. I took the back of my machine off after cleaning the pump twice to find the reservoir full of a brown soap gunk/sludge. there is also a small rubber tube that runs from this reservoir back into the drum which was plugged shut with the same gunk. this thick soap residue can damage the pump motor or slow the drainage system to get the E 04 warning. I cleaned the gray drain hose out with the garden hose and was amazed at the sludge that game out. When the machine would run on the drain cycle we would also get a sewage smell that I thought was coming form the drain trap but turned out to be caused by the sludge in the pump. After cleaning the system and now using no more that a tablespoon of soap it works great & the cloths are clean.
Dec 18, 2008 | Bosch WFMC 3200 Front Load Washer
WFMC 3200 WONT SPIN OR WASH
Open machine's rear panel and look for a broken belt and does the motor spins. Let me know with your results and we will see how could we assist you.
Aug 21, 2007 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
200 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
