Question about Acer Aspire One PC Notebook
Error 13 invalid or unsupported executable format
    Brigadier General:
  • Acer Master
  • 3,400 Answers
When I connect my USB I get an invalid or Unsupported format for videos? why?
Because the format of the video is invalid or unsupported by the video player.
Jan 31, 2015 | Digihome LCD TV
Hp Laserjet 2300 showing error 53.10.03
  • 53.xy.zz
  • CHECK RAM/ROM MEMORY
  • Description
  • There is a problem with the printer random-access memory (RAM) or read-only memory (ROM). The DIMM that caused the error is not used. Values of x, y, and zz, are as follows:
  • x = DIMM type
  • 0 = ROM
  • 1 = RAM
  • y = Device location
  • 0 = Internal memory (ROM or RAM)
  • 1 to 3 = DIMM slot 1, 2, or 3
  • zz = Error number
  • 0 = Unsupported memory (for example, presence detect bad)
  • 2 = Unsupported memory size
  • 3 = Failed RAM test
  • 4 = Exceeded maximum RAM size
  • 5 = Exceeded maximum ROM size
  • 6 = Invalid DIMM speed
Jan 04, 2015 | Office Equipment & Supplies
How ifix a fatal error
Below is a listing of the more commonly experienced processor exceptions ranging from 00 to 0F.
00 = Divide Fault
Occurs if division by zero is attempted or if the result of the operation does not fit in the destination operand.
02=NMI interrupt
Interrupt 2 is reserved for the hardware Non-Maskable-Interrupt condition. No exceptions trap through interrupt 2.
04=Overflow trap
Occurs after an INTRO instruction has executed and the OF bit is set to 1.
05=Bounds Check fault
The array Index is out of range
06=Invalid Opcode fault
This error can be caused by one of the below conditions.
  1. Processor attempting to decode a bit pattern that does not correspond to any legal computer instruction.
  2. Processor attempts to execute an instruction that contains invalid operands.
  3. Processor attempts to execute a protected-mode instruction while running in virtual 8086 mode.
  4. Processor attempts to execute a LOCK prefix with an instruction that cannot be locked.
07=Copressor not available fault.
This error can occur if no math coprocessor is present. This error can also occur when the math coprocessor is used and a task switch is executed.
08=Double Fault.
This error occurs when processing an exception triggers a second exception.
09(OD)=Copressor Segment Overrun.
Floating point operand is outside the segment.
10(0Ah/0A)=Invalid Task State Segment Fault
Can be caused by a number of possibilities as Task State Segment contains a number of descriptors.
11(0Bh)=Not Present Fault
The Not Present interrupt allows the operating system to implement virtual memory through the segmentation mechanism. 0B fault occurs when this segment is not available.
12(0Ch)=Stack Fault
Occurs when instruction refers to memory beyond the limit of the stack segment.
13(Odh)=General Protection Fault
Caused by any condition that is not covered by any of the other processor exceptions. The exception indicates that this program has been corrupted in memory generally resulting in the immediate termination of the program.
14(Oeh)=Page Fault
Occurs when a paging protection rule is violated (when the retrieve fails, data retrieved is invalid or the code that issued the fault broke the protection rule for the processor).
16(10h)=Coprocessor error fault
Occurs when an unmasked floating-point exception has signaled a previous instruction.
17(11h)=Alignment Check Fault
Only used on 80486 computers. Caused when code executing at ring privilege 3 attempts to access a word operand that is not divisible by four, or a long real or temp real whose address is not divisible by eight.
Find out the reason of Fatal Error if that is due to Software related then go in safe mode and uninstall the software recently installed or udate them/patch them. or if the same is related to hardware then unplug the recently added hardware,
please vote
Aug 21, 2011 | Computers & Internet
I wana Install Software eg nimbuzz or other software but unsupported file format problem: could you please give me detail how to solve it thanks
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout
Aug 29, 2010 | Computers & Internet
What does status code-68-cood36be mean . i have downloaded a video from my computer straight to my xbox but wont play because it said it unsupported please advise
This means that the file format you are trying to play is not supported or cannot be played by your console due to format restrictions. It means that the video has an invalid format not recognized by the console that is why it is not playing thus showing this error code.
May 10, 2010 | Microsoft Xbox Console
Error 49 Cycle Power FFF
49 errors are possibly one of the most difficult to diagnose.
49 Indicates that a firmware error occurred that caused the processor on the formatter to abort an operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or home-grown applications.
On some occasions, the formatter is at fault, but this is usually
indicated by a 79 Service Error.
I see you state a 49FFF? any other letters or digits displayed?
Specifically 49 FFFF can be a problem if the ribbon cable from the DC controller to the interconnector board is not connected. The control panel display will also be dark.
Other 49 FFx errors can be:
NEC firmware chip error - replace the Firmware
Unsupported EDO Memory installed - Remove unsupported RAM
Fuser life test error during Boot cycle - Replace the Formatter
A Large print Job (>800 pages) or complex graphics can cause the device to quit printing. - Simplify the Print Job, lower DPI etc.,
Good luck
May 02, 2010 | HP Color LaserJet 4500 Printer
I downloaded framework for my computer and it said to restart so i did and it took me to a chainloader /bootmgr screen and i dont know how to get it awa. it says error 13:invalid or unsupported executable...
Uninstall the framework. If that doesn't work, perform a system restore.
Restore your pc to a date before you installed the framework.
To perform a system restore, follow these steps.
1.Click on start menu
2.Select All programs
3.Select Accessories, then select System tools.
4.Select System Restore.
5.The system restore window will be displayed,
select "Restore to an earlier time"
6. Click on Next
7. Select a restore point, preferably the one before you installed the the frame work and then click on next.
8.Confirm and the system will restore to the point you selected.
Dec 30, 2009 | Dell Latitude D600 Notebook
I have a HANDYCAM SONY DCR-DVD 106, and I keep getting the following message error - "Disc error. Unsupported format - 13:023, with regard to a mini MEMOREX DVD-R.
Disc error. Unsupported format means that ur camera does not support the format of this disc it might not support DVD-R or DVD-RW and supports the DVD+R and +RW try the other format disc and let me know if it resolved , check the manual it is stated on the box or manual which format it supports, if it does not solve ur problem try some other brand instead of MEMOREX try sony,hp,fuji,philips and see actually these sony cameras they are sometimes locked by the manufacturer to only use the original discs for monopoly sony acts like that in every product
pls do rate me if i fixya problem
regards
Zohail
Feb 23, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
Unsupported Format error message
FIRST OF ALL TRY TO PLAY ORIGINAL DVD AND COMEBACK.
Dec 13, 2008 | Bose Lifestyle 18 System
Acer Aspire One  PC Notebook Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
