Question about JVC Ks-r140 2 Shaft / Shafted Classic Oldie Car Style Cassette Am Fm Car Stereo
Need repair
The wires touch together during install,and arced. the component still works but has only very low volume. any suggestions on how to get it repaired
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
You may have blown an audio component when that happened.
Posted on Jul 17, 2013
Amp shutting down when volume gets too high
Easy! You either have a surround speaker wired backwards or there is a break in the wire leading to a surround speaker that is allowing the +&- to arc together. your amp shutsvoff as a protection to keep the arc from reaching the mother board. replace your wires man!!
Nov 29, 2012 | Pioneer Audio Players & Recorders
Hello, I have 7 no. of Philips 105G7 CRT monitors purchased in 2006. 4 of them are working fine but three of them started failing one by one since a year. First was in July last year and the recent one was...
The cracking problem is probably high voltage arcing inside the monitor due to insulation breakdown or components breaking down or dust and moisture causing arcing. I suggest you dispose of these monitors, they could pose a fire risk. Instead of trying to repair them. Do not try to repair the monitors yourself, there are dangerous high voltages inside these crt monitors.
I suggest you put your money towards a LCD monitor, these are fairly cheap and very energy efficient.
Aug 29, 2010 | Philips Computers & Internet
I bought a 20 amp arc welding kit from canadian tire and dont have an instruction manual with it. i have given it the proper electrical current and amperage and still cant get it too work. looking for the...
20 amps seems like a fairly feeble arc welder--most light models run up toward 80 to 100 amps for a stick welder with wire feed models somewhat lower. Even accidently touching the two leads together should have produced some arcing. You may have a defective unit. Hope this helps!
Aug 16, 2010 | Garden
It shuts off right after I turn it on.
Hi....
It's usually a component failure in the power amp section.
There are good tech shops in Cailfornia
Mar 24, 2009 | Denon AVR-1508 Receiver
Hotpoint Aquarius WD440, Rinse Hold, Time Saver and On/Off light flashing
This is typical of a control board problem.
About 60% of the time they can be repaired, but it's easier to replace it than keep testing.
If you are competent at electrical repairs, then read -on, otherwise order a replacement, and have it fitted.
Isolate supply.
Remove top cover by removing screws at top rear, slide cover rearwards.
Control board is on right at the front.
Test connections - remove and replace all connections, checking for signs of arcing.
Check main wiring loom to motor for integrity and damage.
If no signs of damage, remove control unit board, and examine for arcing or poor contacts, overheated components or damage.
If everything still looks ok, a replacement control board should be fitted and the machine tested.
Hope this helps.
Jun 11, 2008 | Hotpoint Aquarius WD640 Front Load...
High volume low sound
check the volume output from your components, and make sure they are not set too low
Dec 08, 2007 | Sony STR-DG510 Receiver
Speaker volume low when set to TV
have you muliple scart leads connected? is everything wired through the tv? is everything wired together? you need 1 scart lead from the tv with enough scart sockets on it to take all your extras.connect your amp through a scart lead aswell.3 things will have to be turned on at all times e.g. tv,sat,amp.Don't connect any 2 extras together e.g. vcr to sat  one will kill the sound from the other
Oct 12, 2007 | Sony STR-DE575 Receiver
JVC Ks-r140 2 Shaft / Shafted Classic Oldie Car Style Cassette Am Fm Car Stereo Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
