Question about Rainbird Sure Pop 600 Series 2-1/2" Pop Up Sprinkler Head
Sprinkler will not pop up - Rainbird Sure Pop 600 Series 2-1/2" Pop Up Sprinkler Head
    Problem Solver:
  • 11 Answers
Most likely cracked inside. Meaning pressure can not build up to "Pop" it up. If you have acces to the same product just unscrew the top and replace with a variable adjust model.
Posted on Jan 11, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 71 Answers
Sounds like "Sure pop" was misleading. Try unscrewing the top or entire sprinkler then the top remove the spray nozzle to access the spring. Stretch it out longer and re-assemble the sprinkler screw it back in place with the spray notches on nozzle facing are you want covered. This should solve the problem if not, replace the pop-up.
Posted on Apr 09, 2014
Garden sprinkler not popping up and not working
Replace that sprinkler head.
Feb 10, 2017 | Garden
Imperial valet timer
Big box stores and sprinkler supply stores.
Aug 22, 2014 | ORBIT UNDERGROUND Sprinkl pop-up 4 adj"
How adjust distance
Turn the sprinkler on. Go to the sprinkler and at the center of the pop-up nozzle you should find a screw.If the screw is there, it can be tightened or loosened to adjust the spray distance.
Jun 21, 2014 | Orbit Irrigation 54196 400 Series...
My sprinkler head is stuck spaying in one spot and I can't figure out how to adjust the range and distance of it.
Sounds like you have a bucket impact sprinkler. These are problematic as they tend to beat themselves into non-operation from the moving parts involved and the impacts. They stop turning for a number of reasons, low water pressure, dirt and debris filling the bucket impeding rotation, plants covering the sprinkler etc. If no debris is found and others continue to work on same zone the water pressure is probably unchanged it may just be tired. I suggest replacing it using a pop-up rotor preferably a Hunter PGP-ADJ or PGJ-ADJ Rotor as rotors have only 1 moving part a gear which is sealed inside the sprinkler making them very dependable.
May 14, 2014 | Orbit Sprinkler System Super-jet 3-inch...
How to adjust the spray pattern on the 570 series pop up
Change the nozzle. If it is an adjustable nozzle change it to a fixed spray with the desired radius. 1/4, 1/3, 1/2, 2/3, 3/4 patterns are available.
Mar 25, 2014 | Toro 570Z Pro Series Black Pop-Up...
My rain bird 1800 head keeps leaking how to fix it
if this is an older sprinkler ,it may just be worn.usually the leak is around the white plastic surrounding the popup shaft.in this event the cap needs to be replaced.
Apr 17, 2013 | Rainbird Rain Bird 1806nsi Pop Up No Side...
Sprinkler head does not spray water
Make sure when you pull the head to ck the screen you turn the system on and blow out the line, then run a hose through the head to make sure it isn't plugged up anyway. Depending on the head and the cost of a new one will dictate cleaning or replacement.
Oct 04, 2009 | Garden
Rainbird Sure Pop 600 Series 2-1/2" Pop Up Sprinkler Head Logo
367 people viewed this question
Top Rainbird Garden Experts
Ted Maxwell
richie46
Gil Shultz
Are you a Rainbird Garden Expert? Answer questions, earn points and help others
