Question about Steinberg WaveLab 5 (502020800) for PC
Steinberg WaveLab 8 for PC - Steinberg WaveLab 5 (502020800) for PC
Cannot open Wave Device for recording. Are you sure your audio card supports the currently specified sample rate and/or bit resolution?
It's basically saying that your inbuilt sound card might not be compatible with the software. Check the software specifications and then look at your sound card specifications. You can also select a different bit rate under the recording options in the software. For example many MP3 files are recorded at 320, but you can reduce it to say 128. This might allow the an older type sound card to work with the software.
May 21, 2016 | Steinberg Media Technologies WaveLab...
Error code 0xco150002
some software just wont work with windows 8 ect.
Aug 19, 2014 | Steinberg Media Technologies Cubase...
Cubase activation code
go to therir website and buy one!
or use a freeware app instead.. like
Audacity
http://audacity.sourceforge.net/
Jul 28, 2014 | Cubase Steinberg WaveLab 7 Audio Editing...
License activayion code
The activation key will be on the cd or in the cd case or on
the box it came in. It is a 5 block of 4 numbers and letters separated by dashes.
May 19, 2013 | Cubase Steinberg WaveLab Elements 7...
How can I get wavelab 4 to work in windows 7?
You can run xp on a virtual machine (VMware or VirtualBox, e.g.) and your program, inside.
On the other hand, Steinberg released version 6 of WaveLab that is compatible with W7.
Mar 22, 2011 | Steinberg WaveLab 4.0 Full Version for PC
Hi, I'm using steinberg cubase3. but after
I don't believe your Bose speakers are digital, you need to change your audio settings on the output to analog speakers.
Mar 17, 2011 | Steinberg Cubase 4 ( Windows / Macintosh )...
I have an m-audio fast track and have 10 sessions recorded. This is perhaps a foolish question, but what is the best software to load these 10 songs into to make a finished album. Thanks.
Do you want to layer the sessions and mix them together? Then Cubase is the best software.
http://www.steinberg.net/en/products/cubase/cubase6_why_cubase.html
OR
Do you just want to edit the sessions individually? Then Wavelab is the best software.
http://www.steinberg.net/en/products/wavelab/why_wavelab.html#c61447
Mar 15, 2011 | M-Audio Fast Track External Sound System
When trying to open WaveLab 6 using Windows 7 I get an Unknown TException error message.
""When trying to open WaveLab 6 using Windows 7 I get an Unknown TException error message."Don't know if this helps. I'm using Win 10 with Presonus Firestudio as my audio interface. I kept getting the unknown TException when I tried to open Wavelab 6. Solved it by going to device manager and disabling the internal AMD sound card and two "High Definition Audio devices" with mfg shown as Microsoft. Must have been hardware conflict between Presonus and internal sound card.
Dec 15, 2010 | Computers & Internet
Usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Apr 01, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Steinberg WaveLab 5 (502020800) for PC Logo
61 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
