Question about Kitchen Appliances - Others
Cuisinart bread maker bkr 400c problems
Where can i bought parts for bread maker bkr 400c i lost the little ringlock under the pan
SOURCE: Need replacement bread pan for West Bend 41042 bread maker
TRY ABTECPARTS.COM
Posted on Nov 13, 2008
SOURCE: Toastmaster 1188 bread maker problem
on my toastmaster1188 when i put all theingredients in to it and it goes throughthe start like spinning it starts to squet could it be the blade or the shaft
Posted on Jan 29, 2009
SOURCE: Can't remove the bread pan
The same thing happened to me yesterday. I made my first loaf and then I couldn't get the bread pan out. We kept pulling and yanking on the bread pan until it felt like it was going to break! This morning, my husband called Cuisinart. The man on the phone said he has the same machine at home, and that you just have to pull it really hard. He said don't worry, it won't break, just pull it. My husband pulled it again and it came out. I guess he just got the right angle on it.
It was definitely stuck from the bottom, not from the side clamp things. The man on the phone at Cuisinart said that after you use it more, it becomes easier to remove the bread pan. We put the bread pan in and then pulled it out a few times, and it seems like now it comes out easily, the way it should.
I felt obliged to respond here, because I was very discouraged after reading this thread last night. I was about to return the machine. I hope this solution helps.
By the way, my first loaf yesterday was the Rosemary Bread from the cookbook that comes with the machine. It was AMAZING.
Posted on May 14, 2009
SOURCE: pan is stuck in my cuisinart cbk-200 breadmaker.
Just pull it.
I had the same problem few moments ago until I read someone's answer.
It really worked and it won't brake.
Posted on Dec 25, 2009
  • 433 Answers
SOURCE: My cuisinart bread maker is making a clicking
If the motor shaft is not turning it could be the belt has fallen off the pulley or the pulley is slipping, or the motor is broken. The motor, pulley and belts are located inside the base of the machine. Hopefully it's just a loose belt. Hank
Posted on Jan 28, 2010
I cannot get my bread pan out of the bread maker, no matter how I try to lift it! The instructions say to tilt it to the left and then pull- which did not work then I followed the suggestion of lifting it...
Most bread machines are held in by 2 little spring clips...one on each side.
They are under tension when the pan is in the oven and that is how it stays stable when kneading is taking place. So to get it out you have to release that tension and that is going take what I call the stern "pop". Grab the handle of the pan right in the center with both hands and put a little slack in it by lowering the handle down about an inch and then "pop" it straight up the little clips will release ther hold on your pan......magic!!
Sep 11, 2011 | Cuisinart CBK-200 Bread Maker
Bread pan stuck-brand new machine Model CBK200WS
They are under tension when the pan is in the oven and that is how it stays stable when kneading is taking place. So to get it out you have to release that tension and that is going take what I call the little "pop". Grab the handle of the pan right in the center with both hands and put a little slack in it by lowering the handle down about an inch and then "pop" it straight up the little clips will release ther hold on your pan......magic!!
Apr 18, 2011 | Cuisinart CBK-200 Bread Maker
My bread pan becomes dislodged many times during the kneading cycle. I have to reset the pan and then continue the cycle. This is a new problem with my Cuisinart Bread Maker. Thanks for your help.
There should be some metal tabs that hold the bread pan in that machine. You probably have to push the pan over them to get it to stay. These become weak sometimes and you just need to try to stretch them out from the inside wall of the bread maker. You want them to stick out more so it puts more pressure onto the pan. Let me know if this doesn't make sense and I'll see if I can explain it a little better. Austin
Feb 28, 2011 | Cuisinart CBK-200 Bread Maker
The bread pan is stuck in machine at the bottom. How can it be removed?
Feb 23, 2011 | Cuisinart CBK-200 Bread Maker
How to remove the pan from the bread maker
Jan 20, 2011 | Cuisinart CBK-200 Bread Maker
The bread pan keeps jumping out of its restraints. There were no problems yesterday. This is the first this has happened.
Try bending the little spring clips outward a little until they grab your pan more snug and try that. This has worked on other machines that had the same problem..If it helps please leave a vote/rank/testimonial etc.....thanks!
Nov 22, 2010 | Cuisinart CBK-200 Bread Maker
I have a new bread maker . When I unpacked it, the bread pail is secured in the machine. Normally, I lift the handle of the pail, twist it and out comes the pail. This is my first Cusisnart, and the...
Hi, those function as little spring clips to hold your pan in. There is no twisting of the pan with your new machine. Just pull straight up with a little "pop" (use both hands and just pop up on the handle) and your pan will pop out. When you bake your first loaf just push the pan straight down until the pan clicks back into place under the little clips and you are ready to bake!
Oct 20, 2010 | Cuisinart CBK-200 Bread Maker
We have a bkr-400c.purchased at Costco in Medicine Hat AB about 1 month ago. We made a loaf of bread and took it out. Turned power off and then made another loaf. Tried to turn it back on without success....
There is no fuse, but there is a feature that will reset after a power loss. This feature lasts for 15 min. Wait longer to see if it works. If not, take it back to Costco for a refund.
Hank
Nov 15, 2009 | Cuisinart CBK-200 Bread Maker
How do i remove the bread pan from the machine it is cuisinart bread maker
 Grasp pan handle with a potholder, press down on outrer housing,lift handle sharply releasing pan .Now who can tell me how to stop my CBK200 from burning each& every loaf?        Dave from Succasunna,N.J.
Dec 11, 2008 | Cuisinart CBK-200 Bread Maker
Kitchen Appliances - Others Logo
29 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
