Question about Samsung SP-R4232 42 in. Plasma HDTV
BLACK SCREEN, AUDIO OK
TV was fine but screen went totally black while watching. Audio is OK. Fuses OK. Can't access menu, change input selection, etc.
  • 2 more comments
  • fishnet Nov 09, 2007
    SP-r4232 sound no picture and nothing dispayed when menu is pressed
  • trav46 Nov 10, 2007
    I have the exact same problem with mine. I was told it could be the logic board but service pretty much changed every board in the thing. I need help.
  • fparras Dec 22, 2007
    My plasma tv will go black off and on constanly while watching TV while the audio is ok
  • Anonymous Feb 11, 2009
    Did anyone solve this problem ? Can they share ?
I have samsung 40" LCD tv and it's happening the same thing. I turned it on and it last for 5 minutes and the screen went back but the audio is fine. I turned off and turned it back on it worked fine but an hour later it happen again.
Posted on Jan 16, 2008
SOURCE:
Has audio, but why did screen go black?
since the self generated menu displays ok id say you don't have a monitor problem , could it be that maybe somehow it got switched over to maybe an "open" input port (example: hdmi-2) as this would explain things a bit , also when you tried the other tv did you use the same cables to connect it as the non working tv ? as that also would explain things
Feb 09, 2016 | Panasonic Viera TC-P46C2 46" Plasma HDTV -...
Channel three is missing
Hi pasu, Normally if you can get/program Chs 2 and/or 4 as well the other channels, then Ch 3 should also be programmable. If this is not possible, perhaps you can try to manually program by selecting "03" and add to the memory "+" in some brands/model. If this is still a no go, perhaps you should seek the services of qualified professional since this would apparently be an internal software problem. You can also try a hard/full reset by unplugging the TV from the mains for couple of hours or as prescribed by your TV's user manual. If the TV has Video input features, a possible temporary work around the TV's Ch3 problem is to use the Video1 or the Audio/Video INput of your TV and use an old VCR to connect to your cable box. Remove the coaxial cable from your cable box to your TV and connect it to the RF/TV INput of your VCR. Use a 3 way RCA to RCA connector (usually Yellow, Red & White) to couple the Audio/Video OUTput of the VCR to the Audio/Video INput of the TV. Select Video mode in your TV (so it doesn't matter even if you cannot program Ch3). Power up your VCR, select Ch3 in your VCR's tuner. I assume that to select channels you wish to view, you use a remote and channel selection is done in your cable box. What worries me is "...went to a fuzzy black and white screen..." which is indicative of another fault. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | Philips Magnavox SC3127N 27" TV
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Sony bravia black screen audio ok
It is a LCD set and if sound get it in a very dark room and with a flashlight and the set on look to see if you see a very faint image on the screen.
Almost all these sets use a back light system for brightness---an inverter of some type to power the lights---either the back light is bad or the voltage for it is not present or being turned on.
Nov 05, 2012 | Sony BRAVIA KDL-52XBR3 Television
I have a blank, black screen, irrespective of the input (cable, dvd, wii). The menus, however, come up fine and the audio is working fine.
Your screen is showing a black picture because the closed caption function has been activated. When the closed caption mode is on the screen will display an 80% black picture.
To turn off the closed caption and regain a full screen please follow these steps;
1) Press the Menu button
2) Use the up and down arrows to navigate to Closed Caption
3) Use the right or left arrows to select it.
4) Use the right or left arrows to select OFF
5) Use the up or down arrows to select Finish
6) Use the right or left arrows to save the settings and exit.
You should have your full screen back now minus the annoying black box.
If this solution has helped please do take a moment to rate it.
Thanks for using FixYa
Dec 25, 2009 | JVC AV-32D305 32" TV
My 46-inch Samsung LCD TV screen went black. Audio works.
If you are seeing light then the back light is working. Can you get a menu?Do any of the other video inputs work? If no video but has backlight and no men or any on screen display replace main board.
Sep 13, 2009 | Televison & Video
Toshiba Regza screen is black but audio works
I unplugged everything and then reset-up the tv, dvd player, audio, and other components.
Dec 29, 2008 | Televison & Video
This morning the screen is black...
The black screen with audio working ok is the inverter card.
Just replaced mine. It is CMO part number VIT70002.00
The inverter provides the high voltage necessary to drive the cold cathode lighting.
A new card is about $180 but shud save having to dump the set.
Card is located on left side of the display (as viewed from the back).
Howard
May 24, 2008 | Niko OTP-3211W 32 in. LCD Television
Have Audio, and backlights, but still no video on Polaroid 3732
try the diffrent inputs HDMI Composite component and see if the video comes on there are 4-10 diffrent inputs on these sets and make sure you select the right input on the menu the remote has a button for inputs a menu comes up and make your selection from there for the right input that you have connected to the tv most menus have TV (air) HDTV (air) video 1-6 HDMI and VGA
Jul 02, 2007 | Polaroid FLM-3732 Television
Samsung SP-R4232 42 in. Plasma HDTV Logo
1,134 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
