Question about Troy Bilt 21A682J766 Horse 8 HP Rear Tine Tiller
Troy built horse rototillers
How do you remove & replace the rear tine shaft & bearings?
  • 45 Answers
SOURCE: Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Posted on Apr 29, 2009
  • 81 Answers
SOURCE: The tines on my troy built Horse tiller do not grb
Since there is no grinding noise, if the problem is in the gear box it isn't too severe. There is a slight possibility that a tooth or two has been broken off one of the gears. But it sounds more like you have a worn drive belt. Most of the time when the tines don't grab or they slip it is because the drive belt have become worn in some way. If it is suppose to be a one-half inch wide belt it could have thinned to a three-eight inch allowing the belt to drop further into the pulley than needed, or it may be "sloppy", not tightening enough to operate the tines if it has stretched. The right belt is very important and is an easy fix. I hope this helps.
Posted on Jun 18, 2009
  • 110 Answers
SOURCE: I need to replace the seals on my Troy-Built Pony
I presume you opened the port and removed the grade 8 placement bolt? If you have then you need to polish the shafts with 400 then 800 sandpaper, clean then lube them before trying to slide thru the support bearings. If your tine shaft is bent? your screwed, or just remove the shaft seals with a screwdriver and replacing them without removing the shaft. REmember to put a thin coat od RTV arround the outer lip to help make a better seal
Posted on Nov 15, 2009
  • 23 Answers
SOURCE: Old Troy Built with model #HH60-105106F. What is
Try partstree.com. It helped me to identify what I needed.
Posted on Jul 04, 2010
mc1bean
  • 3053 Answers
SOURCE: How do we get the
How are you today? I hope well. This is a pretty simple project to get wheel off.
To remove tire & hub from tiller,place tiller on a secure jack or stand,remove front cap,behind wheel in hub & axle you will find a pin that goes through both,punch out with a punch or type of ice pick. You know something similar in your garage if you don't have a punch. Even a small Phillips screw driver could work. Of course when putting back on reverse procedure, might be able to use same pin if not damaged in process of removing it. Hope this helps, Mike
Posted on Sep 23, 2011
Hello,im looking for a manual and parts for my 1996 troybilt tuffy crt rototiller.could you please help me? thanks Leona
Try this website psep.biz they have a lot of stuff there if you are willing to navigate a little.Good Luck...
Jun 04, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
Troy built horse loses power when I engage tines into the dirt. What do I need to service?
sounds like you are trying to till too deep raise tines up a little with the depth gauge then till the same spot again and see if that helps
Mar 10, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Aug 29, 2010 | Troy-Bilt Garden
Where do I find the model number and serial number, it is an old troy bilt rear tine tiller, two speed
The older models do not have an actual model number but only a name to distinguish the size. Early production models include the Horse, Pony and Junior. You must find the location of the serial number tag to order parts that will fit your particular rototiller for seamless replacement of parts. Hope this will help
Apr 23, 2010 | Troy-Bilt Pony Garden Tiller
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How does the gear box come apart on a six horse troy built tiller?
  1. Remove belt guard on left side
  2. Remove belt, large pulley on gearbox.
  3. Remove throttle cable, idler pulley cable and shift handle.
  4. Remove engine, handle, wheels, tines cover and tines.
  5. Lay gearbox on side on two sawhorses, left side facing up
  6. Remove all the nuts on that side. If the three shafts have corrosion, use sandpaper to remove.
  7. Pry the two halves apart, then hammer the ends of the three shafts to push through their bushings. Use brass or wood to avoid blossoming the shaft ends. When shafts are through their bushings, the right side will fall away.
Jan 15, 2010 | Troy-Bilt Pony Garden Tiller
I need to replace the seals on my Troy-Built Pony tiller. 6 hp, ser.# 121811201149. I can not seem to remove the tine shafts. I have pulled the bolt thru the shaft but cannot budge it. Does anyone know...
Nov 15, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How do I remove the wheels on a 1985 Troy Built Horse Rototiller?
Horse wheels are held on with a single roll pin. Pound out the roll pin and pray.....that the rims aren't rusted to the shaft. If the rims are rusted to the shaft, you have two choices. You can either put the new tires or tubes on the rim with the rim on the shaft...or you can work at getting the rims off the shaft. If you put tubes in, be sure the rim is free of sharp edges.....or you'll be sorry.
To get the rims off if they're rusted on, I've used a variety of techniques over the years. The most effective is to weld a nut on the spot where you removed the end caps. Use a nut that's the same thread as your bearing puller. Then use the bolt from your bearing puller to put pressure on the end of the shaft, pulling the rim off. A torch helps, but be careful or you'll be putting new seals in too.
Jun 09, 2009 | Troy-Bilt Pony Garden Tiller
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Transmission oil change.
"ue only G-L 4 gear oil having a viscosity of SAE 85W-140 or SAE 140"
Apr 21, 2009 | Troy-Bilt Chipper Shredder
Troy Bilt 21A682J766 Horse 8 HP Rear Tine Tiller Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
