Question about Sharp AR-M700U Grayscale Copier
Sharp ar-m700 no power
Got no power besides two lights on the boards inside. The main power makes a click inside the machine, but the other power switch doesn't change anything when flipped. All fuses have tested good as well as the switches. No display or movement inside machine or finisher,it never boots. Had a big storm the night before and no surge protector.
    New Friend:
Canon ir 3300 machion no display
Posted on Jul 15, 2013
4 Suggested Answers
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
mickspaceNET
  • 115 Answers
SOURCE: Network Error on display
If you’re getting this on both machines, it is your network...
There a few possibilities...
1. SMTP / DNS Info. Is that correct? Your It can help with this?
go to the Nic page of the machine (IP Address in win explorer) , go to admin page, which the pass word should be sharp , look for the network settings. look at both the smtp info and the gateway and dns info.. Verify that it is correct.
2. Have you changed your Internet Service Provider?
For example, Comcast is making a habit of blocking port 25. Embarq DNS information is a mess, their mail relay is a real hassle.
3. E Mail server information changed? Does your server require authentication, is the Time out set correctly?
Posting the correct codes really help in resolving these issues
Below are a few of the codes...
CE 01 The network card is not installed or broken
CE 02 the specified mail server is server is not found.
CE 03 The specified server suspends response during Transmission of images.
Posted on Oct 23, 2008
  • 3 Answers
SOURCE: error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Posted on Feb 03, 2009
Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Sep 02, 2011 | Sharp AR-M277 Digital Copier Copier
Error Code E7-11 on a Sharp AR-287 photocopier
This code is related to laser unit functioning problem. Power the machine off and on and if it appears again, do the following;
  1. Open document glass and clean inside mirrors and document glass with a clean dry soft cloth and test.
  2. Check flat cable that connects copy lamp and attach firmly from the main board.
  3. Replace the laser unit if the above fails.
Ask for assistance if you doubt from a qualified technician and you will succeed.
Dec 20, 2010 | Sharp AR-M205 Copier
Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier not workig digital F5 blinging
Hallow, this is a problem with the exposure lamp on the document glass which is not working or if it is lighting, it is not sensing the white mark on the cover which is above it.
Remedy
Please check if the cover that locks the glass is well screwed or present.
Check if the copy lamp is lighting and replace with a working one.
Check if its cable is not disconnected on its power board located beneath it.
Replace the main board of the machine.
Nb use that sequence to solve your problem and good luck.
Oct 18, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M550 with a paper tray error F3-12
When I first arrive to any service call the first thing I look for is the service log.
Locate the service log on the rear,side or inside the front cover.
Check the last error code and corrective action.
F3-12, Paper does not lift in the tray
Identify how many lift tray is inside your machine.
Check each sensor(s) for smooth operation.
LOOK inside for crack plastic on the lift tray.
Sensor can be defective (non-operational) and no cutting off power to the motor and damage the motor,metal frame and plastic tray.
Use a small METRO VACUUM with a clean bag,
Vac the interior of the unit,
Look for fragment of plastic tray or sensor arm inside the vacuum bag.
Pass the information to a Sharp authorize shop.
Dec 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-287 fault code E7-11
Hello sir; The error code means there have communication problem between main board and sub board,operation board, icu board or print, my suggestion, go buy a new copier, it not worthy to repair !
Feb 27, 2009 | Sharp AR-235 Copier
Sharp AR-507 code E7-00
ICU Communication error. Could be a problem with the ICU board or the connection between it and the PCU board. If resetting the machine (main power off and on) does not solve the problem you'll likely need a service call from a copier tech.
Oct 07, 2008 | Sharp AR-507 Copier
Sharp AR-5320 giving me L 4 error some time
Usually the error is caused by a main drive over load. The machine needs to be looked to determine if its the motor, power supply, or a board.
Sep 19, 2008 | Sharp AR-5320 Black and White Copier
Sharp ar-5316 E Problem
Make sure that the side door is secured. There is a corona wire in a brakced on the door and if it does touch the rest of the machine correctly, blank pages will spit out.
Aug 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Have you setup your smtp address on the machine? From any workstation in the same network open your web browser. Key in the IP address of the mfp copier. Goes to network setup and key-in your smtp address.
Sep 14, 2007 | Sharp AR-M277 Black and White Copier
Sharp AR-M700U Grayscale Copier Logo
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
