Question about Vehicle Parts & Accessories
More power 84 6.9 ford f250
Need more pulling power this truck is stock all but I fliped over the top of the breather to get more air
  • 109 Answers
You could change the gears in the rear end for more toque
Posted on Jul 15, 2013
How do i find the door code for a ford superduty f250
should be on the maps box . pull out the insides of the glove box that is sit on top of it.
Aug 09, 2014 | Ford F-250 Cars & Trucks
1999 ford f250 super duty with 5.4 liter gas engine. moaning noise comes from air intake assemblly somewhere before or right at where it enters throttle body. very loud noise and very annoying. mostly at...
This may just be a loose clamp or possibly a clogged air filter, inspect it closely for free play in the hose and breather box area, tighten anything that appears loose and try it again.
Sep 15, 2011 | Ford F-250 Cars & Trucks
My 84 ford f250 6.9 diesel. Starts and then dies and wont start.
could have a bad fuel transfer pump ( block mounted) or air getting into fuel system. This could be caused by a pin hole in the fuel lines ( supply or return) have someone crank it over for you while you press the shrader valeve on the fuel filter housing , see if you are getting fuel or air. Could also be an injection pump problem. Best thing would be to have it checked by a qualified diesel mechanic, as this could be caused by many different things. Kinda costly to throw parts at it on a guess without proper testing
Apr 17, 2010 | 1983 Ford F 250
99 f250 7.3......has been running rough mid throttle, yesterday on the highway it died but started back up before i could get pulled over,today it shut off and stated it back up and made it home...i have...
spray some carb cleaner down the breather pipe the carb could be clogged up so it is not opening properly and choking the engine or flush out your feul they may be dirty and your not getting enough fuel through when you need it or your air intake senser might need changing cus if your air/fuel mix is wrong your engine will stall
Mar 22, 2010 | 1999 Ford F250 Regular Cab
Where can i find a replacement power window wiring harness parts for my 97 f250 crew cab?
Best solution is Ford Dealer, they are little pricey but it is original part that they stock, or you can try it at JCWhitney.com
Feb 18, 2010 | 1997 Ford F250 SuperCab
I have a 2004 f250 crew cab what size are the door speakers in the front and rear
i have an 84 ford f-250 and im looking for after market door speakers can anyone help?
Dec 24, 2009 | 2004 Ford F250
I have a 1999 Ford F-250 and it has a Banks Programmer on it. Anyway, it misses a little while it is just running but sitting still and when driving it starts stuttering around 1500 RPM's. Once you give it...
Put it back to stock programming, clear the codes and see what happens. Even though you will lose the extra power from the programmer at least it will run.
Mar 15, 2009 | 2004 Ford F250
Ignition timing
if you bring the engine up to top dead center on the #1 cylinder and then mark the distributor housing for #1 sparkplug wire , remove the cap and then turn housing untill rotor points at mark then reinstall cap . This will get you started . then using a timing light check the mark on the damper and the the timing to 8 degrees btd .
Nov 16, 2008 | 1984 Ford F 250
Vacuum pump wiring
I have 84 & 85 Ford F250 4X4 w/ 6.9 diesel and they use a belt driven vacuum mounted below the alternator driven by a short belt from the alternator.
Have never seen an OEM electric vacuum pump on any Ford F250 w/ 6.9 diesel and early 7.3 non powerstroke.
This must be an after market unit, so look for marking or ID on it to find who made it.
Best guess on wiring, unit may be 2 speed, with black being common or ground and red for power.
kmk
Jun 29, 2008 | 1984 Ford F 250
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
