Question about Cameras
Sony cybershot dsc-w510 not starts-up
Sony cybershot dsc-w510 starts initialize settings then entered all settings such as date and time then finished camera lens pop up but screen shows blank and camera not start. please help me for solutions.sony cybershot dsc-w510 starts initialize settings then entered all settings such as date and time then finished camera lens pop up but screen shows blank and camera not start. please help me for solutions. a month ago my friend dropped my cam on dust. then camera lens not load fully then cam shows start t agian turn of and turn on. so i did initialize using cam function on picture view mode. but shows above initialze settings shows again evvery starts up camera. i screwed cam repaired lens mechanical problems. now lens works fine but camera not bootup every starts up shows initialzie settings then finished camera screen becoming dark only turn off by removing battery. is there any way to repair this prob such as reprogram or upgrading camera program any other way. plz help me
  • BOIDOO Jul 15, 2013
    thanks alot for all. i live in Mongolia I think here isn't sony support center. i think lens stuck repaired common problem is cam not fully start after initialized
SOURCE: Viewing is fine, taking pictures is not
My one got the same problem. the solution posted on Feb 11, 2007 really works. Thanks。
Posted on Oct 15, 2007
zohail
  • 1223 Answers
SOURCE: No view on screen of what is showing in front of lens. Menu and playback shows but nothing when i turn to camera mode or video mode.help!
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Posted on May 05, 2009
Rammsteins
  • 300 Answers
SOURCE: sony Cybershot DSC-W150-turn power on, lens zooms
Hi!
It's probably stuck focus. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Posted on Jul 29, 2009
SOURCE: sony Cybershot DSC-W150,screen reads turn power on and off again
You may not believe this and I hope you haven't spent a lot of money fixing your problem. I read that some people had a different error message coming up on their Sony Cybershot DSC-W150's and in order to fix it, they literally banged the lens against their knee while the lens was out and it re-focused and the error message disappeared. I tried this while my camera was doing exactly what you described above AND IT WORKED!!!!!!!!!!!!!!!!!!!!
After 2 or 3 firm blows, my LCD screen came up and focused. I can't believe it myself, but I was just desperate enough to try it and VOILA!
Good luck!!
Posted on Aug 30, 2009
SOURCE: Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Posted on Mar 02, 2010
How do i use my sony W510 cybershot as a webcam?
Have togo to setting on computer an add the new device while plugged in.
Sep 18, 2012 | Sony DSC-W510/S - La Cybershot W510 Silver...
How to use cybershot sony W510 as a webcam?
If you go on this link it will tell you what to do. Link below.
http://www.ehow.com/how_5033685_use-cybershot-webcam.html
Hope this helps.
Sep 18, 2012 | Sony Cyber-shot DSC-W50 Digital Camera
SonyManual for Cybershot DSC-W290
Go to setting then select date & then time change then and save the settintg.
Aug 08, 2012 | Sony Cameras
How can I set my DSC -W510 to black and white color mode?
According with your Sony Cyber-shot DSC-W510 Operating Instruction Manual - English & Spanish... check SETTING ITEMS.
Hope this helps (remember to rate and comment this free answer).
Jul 16, 2011 | Sony DSC-W510 Digital Camera
WHEN I INSERT MY MEMORY CARD IN MY SONY CYBERSHOT DSC W510 IT SAYS MEMORY CARD LOCK.....HOW CAN I UNLOCK THIS ?
Hello there And Welcome to Fixya !
First of all there isn't any problem with your memory card or camera .
Take out the memory card from your camera and take a look at memory card , there will be a lock pin on the memory card .just unlock it with your finger cause it has a tiny knob
Do comment if it helps you in any manner
Apr 26, 2011 | Sony DSC-W510 Digital Camera
SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
Feb 17, 2010 | Sony Cybershot DSC-H3 Digital Camera
Unable to change the time settings
In Sony DSC-S950, press Menu button, go to Setup menu, Clock settings and adjust time and date, press OK, press Menu button to exit.
Thanks.
Sep 19, 2009 | Sony Cybershot DSC-S950 Digital Camera
TIME DATE STAMP
push the wtz key its number 1
Aug 19, 2008 | Sony Cybershot S650 Digital Camera
SONY Cybershot 6.0 stuck on record
Initialize the Camera; select Initialize under Setup 2 Menu in the Main Menu. Reset the time and date. This should help
Aug 19, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
