Question about Video Game Consoles & Games
I have a wireless controller for a play station 2 works for a bout a minute then loose everything take battery out put back in does same thing
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
Make sure that they are connected to the receivers
Posted on Jul 17, 2013
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: play station 2 not working
there are electronic fuses inside that most likely went have to send in for service.
Posted on Feb 04, 2008
  • 12 Answers
SOURCE: I'm putting new batteries in my wireless
clean the contacts with something, isopropyl alcohol works fine
Posted on Jan 09, 2010
jcox2820
  • 78 Answers
SOURCE: I have a play station
First, check to see if your memory card has any room on it by turning on your PS2 while there is no game in the machine. Select your memory card, and see how many blocks are left on it, then see how many blocks are required to save Crash Bandicoot 2 games (should tell you on the game's box).
If there isn't enough room, delete some saves to make room.
If there is room, or you cannot view the saved data on your memory card then try putting it in the other slot. If putting it in the other slot does not fix the problem then your card is either damaged or the data is corrupted. In either case, you will simply need to use a different memory card.
Posted on Mar 11, 2011
SOURCE: Will a wireless guitar hero controller for Xbox work on play station?
Nope has to be a playstation guitar hero guitar.
Posted on Nov 22, 2012
I have a 2010 Corolla and last nite I started the car and my check engine lite and vsc off was flashing. I recently replaced my brake pads and front rotors. Could that be the problem. What should I do? I...
First of all , is every thing working ok?. are the brakes working ok?. Did you uncouple the brake hoses and loose brake fluid or just pushed the pistons back into the housing, If every thing checks out ok, Reset the computer , by removing the + terminal on the battery for a few minutes. you will need the code to reset the wireless.
Oct 13, 2014 | 2010 Toyota Corolla
2006 infiniti m35 no sound from speakers
Yes an amp that is not working could cause this to happen. But I would check it out a little more because when you did the speaker test and all the speakers worked then that doesn't sound right. Find the amp and it could be just a loose connection that is giving you all these problems. Good Luck
Mar 12, 2014 | Car Audio & Video
X box controller keeps turning itself off - I have put new batteries in
Connection problems might be caused by one or more of the following factors:
  • Weak batteries or a weak Xbox 360 Rechargeable Battery Pack
  • Interference from another wireless device, such as a microwave oven, a cordless phone, or a wireless router
  • Metallic objects positioned between the console and the wireless controller, such as a chrome faceplate or metal dividers, shelves, or doors on an entertainment center cabinet
    Note All licensed Xbox 360 console faceplates are tested for interference, and do not interfere with licensed wireless devices.
  • There are already four controllers connected to the console.
uparrow.gifBack to the top THINGS TO TRY Solution 1: Restart your console Turn your console off, wait a minute, and then... Solution 1: Restart your consoleTurn your console off, wait a minute, and then turn it on again.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 2: Replace the batteries or the Rechargeable Battery PackInsert fresh AA batteries, or attach a fully charged Xbox 360 Rechargeable Battery Pack to your controller. If you have an Xbox 360 Rechargeable Battery Pack
  • Remove the battery pack and reattach it to your controller, making sure that it is attached correctly.
  • Press and hold the Xbox Guide button. In the upper-left area of the Xbox Guide button, the battery meter indicates your current level of battery strength. You might need to recharge the battery pack, if the level is low.
If you have an Xbox 360 Play & Charge kit
  • Make sure that the Xbox 360 Rechargeable Battery Pack is correctly connected to your controller and plugged into one of your console's USB ports. If you check both of those things but are still having the problem, try the suggestion below.
  • Plug the charge cable into each USB port on your console, one by one. There are two USB ports on the front of the console and one on the back. If the controller works in one USB port but not another, try another accessory in the USB port that did not work with the controller. If the USB port does not work with any accessory, your Xbox 360 console might need to be repaired.
  • Turn off vibration feedback (rumbling) on the controller. If you play games with feedback while charging, it takes longer for the controller to charge and might drain the battery pack faster than it can recharge. Here's how to turn vibration off.
    1. Press the Xbox Guide button on the controller.
    2. Go to the Settings area, and then select Preferences.
    3. Select Vibration.
    4. Select Enable Vibration to clear the checkbox.
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 3: Remove objects between the controller and the consoleThe controller works within 33 feet (10 meters) of your console. However, objects placed between the controller and the console might reduce this range. In addition, objects that use wireless technology (for example, a cordless phone) can interfere with your wireless controller. Remove or relocate objects or wireless devices that might interfere with the wireless controller or console. Here are some things that can cause problems:
  • Microwave ovens
  • Cordless phones
  • Wireless routers
  • Chrome faceplates
  • Metal dividers
  • Shelves
  • Doors on an entertainment center cabinet
If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 4: Disconnect all controllers and headsetsIf all four rings surrounding the power button on the console are green but the controller has four flashing green lights, four controllers might already be connected to the console. Disconnect all of the controllers, and then try to connect the controller with the problem.
  • To disconnect a wireless controller, press and hold the Xbox Guide button for three seconds, and then turn the controller off.
  • To disconnect a wireless headset, turn the headset off.
  • To disconnect a wired controller or headset, unplug its cable from the console.
To learn more about connecting your wireless controller, please read the following Knowledge Base article: 906947 (http://support.microsoft.com/kb/906947/ ) How to connect an Xbox 360 Wireless Controller to an Xbox 360 console or computer If your controller is still not working, try the next solution. uparrow.gifBack to the top Solution 5: Replace your controllerIf your controller still does not work correctly, it might need to be replaced. Please contact Xbox support at the following address: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) uparrow.gifBack to the top Additional supportPlease visit the following Web site for information about how to contact Xbox support: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact)
Dec 05, 2010 | Microsoft Xbox 360 Controller
Have a 2006 Heritage Softail - Was running when speedometer & odometer quit working and key light came on - not engine light. Stopped at gas station - when down shifted to stop things started working...
Hi Johnrobindan, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below and good Luck.
Harley Diagnostic Codes 04 to Present
Aug 24, 2010 | Harley Davidson FLSTCI Heritage Classic...
We have a play station 2, and purchased the Guitar heros world tour game with it. Everything worked fine , then we purchased the guitar hero legends of rock and everything worked fine for a little while,...
i would suggest getting a new guitar for the Guitar Hero. if you do such things as excessively or harshefully drop it, wrap/ overextend the cord as to tearing the inside copper away causing a faulty electrical current,etc. damaging it, or applying too much pressure to the buttons. these will result in a malfunctioning guitar themed controller. bu a new one.
Nov 14, 2009 | Video Game Consoles & Games
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
My xbox 360 wirless controller wont tern on period
There may be a problem with the batterie connectors on the back, make sure they are clean. Also, you might buy the wireless accessory set, which comes with chargable batteries and the charging cord, with which you do not need batteries, and might bypass the problem you have.
Sep 16, 2009 | Microsoft Xbox 360 Controller
Xbox 360 Not Reading Disks
idk bout the blue screen. but my console would say the same thing bout put in 360 to play and it wuz cuz the disk was dug in a lil bit so it wouldnt read.
Dec 31, 2008 | Microsoft Xbox 360 Console
Xbox 360 wireless control conects then disconnects randomly
I finally gave up and called the Geek Squad at Best Buy. I took it in for them to look at and after only 5 minutes, the very helpful young man said it was not working properly and suggested I return it and get a new one. So far everything works GREAT!!!!!
Dec 26, 2008 | Microsoft Xbox 360 Controller
Video Game Consoles & Games Logo
12 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
