Question about Bravetti Crock Pots & Slow Cookers
Receptacle j ai brise mon couvercle de ma mijoteuse est-il possible d en acheter un nouveau et quel en est le prix
Salmonella on raw chicken, do not wash?
http://www.cdc.gov/salmonella/general/prevention.html
also use separate chopping boards
https://www.foodsafety.gov/keep/basics/separate/
Cut up chicken does not go with Salad / un cooked foods on same chopping board and hands with cut up chicken does not go with with Salad / un cooked foods
Eggs are another source - had a bad food poisoning incident in Melbourne Australia caused by eggs in Mayonnaise.
http://www.dailymail.co.uk/health/article-2055844/Never-meat-shelf-beware-raw-vegetables-Could-fridge-KILL-YOU.html
Meat never goes on top shelf !
Oct 29, 2016 | Crock Pots & Slow Cookers
3 in 1 electric multi cooker
If you want to let it sit charge and I'll get hot that it plug-ins and dump it out on plug it's wrapped of quarter round the bottom of it and then unplug it and plug it back in
Jan 28, 2014 | Crock Pots & Slow Cookers
Slow cooker light does not come on and crock does not heat up when plugged in
Have you checked another receptacle? If you plug it into a known good receptacle, and it still doesn't work, it's broken. You should just buy a new one.
May 06, 2011 | Rival SCVP609 6-Quart Slow Cooker
Need a power cord for a Nesco model 4946-10 6 qt. roaster oven
You can find replacement cords for counter top appliances at most hardware and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you get the correct cord.
Apr 26, 2010 | Nesco 4816-14-30 6-Quart
I have a goldstar microwave model ma-1301 rv Whats the smallest generator that can run this safely?
A 1,500 watt generator will run this microwave. Do not get anything any smaller. The microwave will more than likely pull at least 900 watts but you need some reserve. A 1,000 watt generator might be able to supply enough power but to be safe and sure, get a 1,500 watt. Look on the microwave and see exactly what the power output is and make sure you get a generator with some reserve. If you find this is a 700 watt microwave then a 1,000 watt generator will be fine but later on you may want a larger microwave.
Dec 16, 2009 | Crock Pots & Slow Cookers
Crock pot lid
www.rivalproducts.com if it's a rival brand crock pot. if not google the company and contct them about replacement parts, or large stores like canadian tire that carry the product will put you in touch with the manufactuers to get parts.
good luck
Aug 12, 2008 | Crock Pots & Slow Cookers
Need plastic handle on Rival Crockpot lid.
J'aie un crok pot Bravetti de 7 pintes, c'est une petite merveille jusqu'à aujourd'hui car une de mes poignées s'est cassée lors de son utilisation. Je ne l'aie pas cognée, j'aie seulement pris mon crock pot ( qui était en pleine cuisson depuis 4 h00) par les deux poignées pour le changer de place sur mon comptoir de cuisine et crack, la poignée m'est resté dans les mains. Je n'ose pas imaginer ce qui aurait put arriver si il y avait eue un enfant près de moi lors du déplacement de mon crock pot Bravetti 7 pintes en inox. J'aurrais pu brulé quelqu'un pour le reste de sa vie....ATTENTION lors du déplacement de votre crock pot car les poignées ne sont pas solide du tout, je suis vraiment décue car j'adorais utiliser mon crock pot mais à partir de maintenant.....je vais y penser à deux fois avant de m'en procurer un autre Bravetti 7 pintes en inox.
Lyne
Abitibi
Aug 10, 2008 | Crock Pots & Slow Cookers
I don't have instructions/receipes
If you go directly to GE they can help you:
http://www.geappliances.com/
Or you can et recipes by searching Google. Or try this link as a started:
http://www.livingit.com/food/food/pgrecipiehome.aspx
Good luck
Mar 15, 2008 | GE 106661 4.5-Quart
Where can i obtain a replacement cover
If you dont have the owners manual to contact the company, your out of luck unless someone else has a distribution name and addy. Last time i tryed to get a cover for one of our crock pots, the shipping and handling as well as the part cost almost more then the entire crock pot.. Go figure! good Luck
Jul 25, 2006 | Le Chef LSC7100 7-Quart
Crock Pots & Slow Cookers Logo
26 people viewed this question
Top Bravetti Crock Pots & Slow Cookers Experts
charles
Henry  Thomas
Henry Thomas
Are you a Bravetti Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
