Question about Garden
Troy built Bronco gas pedal bounces when pressed
4 Suggested Answers
SOURCE: BELT PLACMENT ON TROY BUILT TILLER MODEL
I am assuming your belt broke and you cannot find the replacement.
I had to go to an old timer that owns his independent business and he was able to find a much better belt than the one that came on the tiller. The Belt # is 1916657 and it is 25.5 inches long and 1/2 inches wide. It also has a kevelar core that will stand up to the constant gearing up and down.
Lowes was NO HELP AT ALL!!!!
Hope this at leasst get;s you in the right direction
Posted on Apr 25, 2009
jyackle5
  • 8197 Answers
SOURCE: I NEED A DIAGRAM OF A BRIGGS AND STRATTON TROY
Go to link below for a parts break down for your tiller. Starts on page 23
http://dl.owneriq.net/c/c23c1d7c-74ff-4347-b31e-a0ee0462b35e.pdf
Posted on Apr 17, 2010
SOURCE: troy-bilt bronco leaks gas from the air filter
I have this exact problem also. I have found, in my situation, that the float bowl has developed a pinhole in it, allowing it to fill partially with gas. Simply put, bowl gets heavy doesn't float, gas doesn't get shut off and gas comes out of the air filter. My problem developed because I normallly run all gas out of tank before I store it for the winter. The brass float came in contact with the aluminum bowl housing and badda bing badda boom, electrolysis in action! I was able to repair the bowl housing with some 2-part epoxy, but I will have to replace the brass float.
Posted on May 17, 2012
Where can I get all three belt diagrams for a troy built bronco riding lawn tractor model# 13AV67KG
Troy Bilt Deck belt Replacement - YouTube
? 11:46
www.youtube.com/watch?v=w3SrErGTyoY
Apr 1, 2014 - Uploaded by Murray Mayhem
I got a good one troy bilt bronco having problems finding the right deck belt for it. I use the model number under the seat but they are too long ..
Jul 09, 2015 | Troy Garden
Where are the grease fittings ona Troy built riding Lawnmower that has a19hp Koehler engine and the mower is called bronco
There are only 4 I know of inside the 2 front wheels on the axle and 2 on the steering knuckles.. you may have some on the deck spindles but most of them are sealed now days
Apr 24, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
My Troy-built Bronco riding mower gets gas to the carb, but there doesn't appear to be any getting to the spark plug. Any suggestions?
there is a solenoid on the bottom of the carb you need to see if your getting power to the connector if you have power the solenoid is stuck if not there is a safety switch on the clutch/brake pedal that goes bad
May 07, 2012 | Troy Garden
Troy Built Tiller - How much oil does it take?
About a quart ... but dont overfill. There is a dip stick on the engine.
Aug 03, 2010 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
Troy built lawn mower (riding) won't go full
I did not know riding mower had a gas pedal. I know if you leave the throttle control up all the way the engine will choke out. The pedal you are pushing, I think, is the forward/reverse hydrostatic transmission. You may need a new drive belt. The one you have now may be stretched out.
Good Day.
Oct 07, 2009 | Troy Garden
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
