I have a umc tv, every time I switch it on it says scanning, do not power off, it will reach 100% and start again? Please help.
2 Suggested Answers
  • 24 Answers
SOURCE: my UMC tv keeps comen up scan and gets to 100% and
Hi Ziggy. Firmware issue on your main AV board my friend. I have heard of this with UMCs before.
You could try a factory reset. If that doesn't work, you could try updating the firmware with a usb flash drive - you would have to find the firmware for your particular model from the manufacturer's website (assuming they have one).
If that doesn't work:
Obviously, if it is under warranty contact the seller or the manufacturer and they should sort it out for you.
If it is out of warranty then you could try replacing your AV board. Spare parts from TVs damaged in transit or used parts are often listed on eBay and other specialist TV parts websites.
You would have to open the back - remember to UNPLUG IT FIRST - and you're looking for the big circuit board that has all the video inputs in. Find the part number on it and search it on eBay or a site like www.flattvparts.co.uk - replace the board and (assuming they sent you a working board) that should solve your issue.
Posted on Jun 19, 2013
Hi, Can any one please shed any light on my problem, When I switch the tv on it says DO NOT POWER OFF and under that SCAN it scans upto 100% then scans again upto 100% and again and again does not stop...
Try a hard reset by unplugging the tv while it is turned on. Then push and hold the power button for a few minutes to drain the electronics and memory of all. Then release button and replug back into outlet and then turn on to see if that has done the trick. If that does not work you can contact tech services for a hidden code to restore unit to factory defaults.
Sep 09, 2017 | Televison & Video
TV not turning on
Main system control memory IC damaged. Replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 15, 2014 | Televison & Video
When tv goes on stanby it starts scanning
The firmware corrupted. Contact the authorized service centre.
Apr 09, 2014 | Televison & Video
46/188g-gb-5b-ftcu-uk umc tv just keeps saying scanning it goes from 0% to 100% then starts all over again ???? also it is upside down ????? any help would be great
It sounds that the main system memory IC to this set is faulty. Check and replace it. It is a very small IC, having 8 solder terminals, can be located very near to main system control IC. Contact any service technician. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 09, 2013 | LG 42LC2D 42 in. LCD HDTV
Saying scan everytime tv switches on
just been told by the makers, its the power board that has an update chip onboard which should Not have been there.
Nov 19, 2013 | Televison & Video
Umc 32" lcd sound just goes off after less than 1hour. if switch off and leave 10 mins then switch on sound comes on again for a short time.
It sounds like a thermal component issue since it happens only after playing for awhile. This type of problem is often an issue with the power supply. A link to a TV board distributor is below.
www.tristatemodule.com
Nov 04, 2013 | Dynex DX-L42-10A 42 in. LCD TV
My UMC tv keeps comen up scan and gets to 100% and then start all over again help please
Jun 18, 2013 | Televison & Video
UMC TV Forgets all the scanned channels if it is switched off
There is a problem with the memory part of the TV where the last selections are stored. This may need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
I have a UMC LCD *** DVD TV, it stopped working and not switching on..the power is not supplied to the tv.The TV power adapter green light is nt flickering. Need help
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
Aug 22, 2011 | Televison & Video
Televison & Video Logo
582 people viewed this question
Top Televison & Video Experts
