Question about Cell Phones
Unlock setting weierwei - Cell Phones
Unlock code
g mail addres dalne per bhee unlok nahi ho raha hai
Jan 03, 2014 | ZTE Cell Phones
No prompt to unlock for network
Instructions to enter the unlock code on HTC Touch pro 2 Verizon:
From Home Screen go to "Settings" tab and click the left soft button for "All Settings."
Click on the "Personal" tab at the bottom.
Click on the "Security" icon.
Enter the unlock code you were provided.
Network Settings:
Click on the "Phone" icon (next to "Security" under "Settings" -> "Personal" tab)
Go to "Network" tab.
Choose "GSM/UMTS only."
Click on the "GSM/UMTS" tab, click on "Band," and hit "Get Settings" and you'll find various band options depending on which SIM card you put
Follow the link to get HTC Unlock Code
Apr 21, 2013 | HTC Cell Phones
Zte x500 need unlock code?
Go to Menu-Settings-LOCATION & SECURITY-Set up screen lock to set the
unlock pattern. If the unlock pattern is entered incorrectly 5 times in a row, the handset will give you a hint to unlock by entering g-mail account, or continue to enter the unlock pattern after 30 seconds. There will be no trouble as long as you remember your unlock pattern. If users didn't bundle with the g-mail account when using Google handset for the first time, then they can't also use g-mail account to unlock after they forget the unlock pattern. The only way is to refresh, however, you should be cautious that this might cause your user data loss.
Dec 13, 2012 | ZTE Cell Phones
I want to unlock my mobile samsung champ gt c3303k so i can insert other sim card to it.
You can unlock the samsung C3303K champ easily,You can use the unlock code to unlock it...get the unlock code from the site
Unlocking4u.com and unlock it,then use any GSM Network Sim card.
Aug 08, 2011 | Cell Phones
A Friend gave me his LG flip phone and also had forgotten his unlock code so that I reset it to factory default settings. Hope you can help out as I would like to get my new phone working like new when you...
You can't just reset to default factory setting to use that phone. That phone need unlock code and you can get LG GW300 unlock code from your vendor provider with some charge up to $80 or you can buy lg unlock code from third party sites with more cheap price.
Mar 20, 2011 | LG GW300 Cell Phone
How do i manually release the rear door on a ssab 9-3 2003 as the door module has failed
Trunk Lock After Closing
Desc.: What happens to the trunk lock when closing it.
Settings:
Yes: Automatically lock Boot on closing
No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
Desc.: Should the trunk be locked at drive off or after 30 sec.?
Settings:
Yes: Trunk/Boot will automatically lock when vehicle increases speed
No: Trunk/Boot will remain closed, however will be in the unlocked
condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
Desc.: When the is removed from the center console should door/trunk
be unlocked?
Settings:
Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
the Ignition Switch If Driver frequently locked all Doors when
driving
this feature would be beneficial.
No: Doors and Boot will remain in the same condition as they were
prior
to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock
Mode
TSL at Second Press: All Doors will lock in Deadlock mode at the second
press of the Remote.
* Lock /Unlock Acknowledge
Settings:
None : No acknowledge will be visible
Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
Settings:
This Feature can be turned on or Off .Yes / No can be selected.
Low Beam Automatic / Low Beam also in Position 0 (light switch)
Yes / No
- Daytime Driving Lights can be activated
* Parking Lights
Settings:
Act as Lead Me To the Car Light.
* Park Light On Reminder
Settings:
On / Off
If Ignition is turned Off and the parking lights are active, Driver will
be warned if set to on.
* Show Trailer Light Outage
Desc.: REC will detect blown trailer light and display on SID
Settings:
Yes or No
* Trailer Light / Fog Light off
Settings:
Yes: Fog Light Rear will be disabled When Trailer is connected Yes
No
* Horn Lock Unlock Acknowledge
Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
- Panic Button / Locking Switch
Central Locking Switch Driver /Passenger
Settings:
- Panic Button on Remote and locking switch inside vehicle will
activate alarm
- Panic Button will activate Alarm only
- Locking Switch inside vehicle (driver /passenger will activate
alarm only
- No Panic Alarm function required.
* Unlock Logic
Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the
Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
& Fuel Lid will unlock when door
switch is activated
* Remote unlocking One Press
Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the
Remote is pressed
Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
Fuel Lid will unlock when the Remote
is pressed
Dec 17, 2010 | 2003 Saab 9-3
I want to set up my yahoo email on unlocked blackberry storm
go to messages, then go to e-mail and select set up a new email account,
put your yahoo account details, select your access point and other settings and yo ur done...
connect to wifi or internet and download ur mails on ur mobile.
Jan 10, 2010 | RIM BlackBerry Storm 9530 Smartphone
Samsung L770 unlocking
Contact your service provider and they can unlock it for you.
Feb 25, 2009 | Samsung SGH-L760v Cellular Phone
How to get OK-CLR sequence to unlock keyguard??
I have a black one too, but I was able to set both the OK and CLR buttons to unlock it. If you go into the settings on the front keypad, go down to keyguard settings, then unlock options, you should be able to choose Two Step Unlock. That will enable you to hit OK then CLR to unlock.
Dec 30, 2008 | LG enV VX9900 Cellular Phone
Factory ringtones
Sir,
You can lock your phone manually or set the phone to
lock automatically whenever you turn it off.
To use a locked phone, you must enter the unlock
code. A locked phone still rings or vibrates for incoming
calls or messages, but you must unlock it to answer.
You can make emergency calls on your phone even when
it is locked (see page 68).
Locking Your Phone Manually
Find the Feature > Settings > Security
> Phone Lock > Lock Now
Unlocking Your Phone
Tip: Your phone’s unlock code is originally set to 1234.
Your service provider may reset the unlock code to the last
4 digits of your phone number.
Setting Your Phone to Lock Automatically
You can set your phone to lock every time you turn it
off:
Find the Feature M> Settings > Security
> Phone Lock
> Automatic Lock > On
If You Forget a Code, PIN, or
Password
Note: Your phone’s 4-digit unlock code is originally set to
1234, and the 6-digit security code is originally set to
000000. Your service provider may reset the unlock code
to the last 4 digits of your phone number before you
receive your phone.
Press To
1 keypad keys enter your unlock code
2 OK (+) unlock your phone
> Phone Lock
Master
Clear
Clear all user settings and entries
except SIM card information, erase all
downloaded pictures and sound files,
reset all options except unlock code,
security code, and lifetime timer:
M > Settings > Initial Setup
> Master Clear
Caution: Master clear erases all
user-entered information (including
phonebook and datebook entries) and
user-downloaded content (including
photos and sounds) stored in your
phone’s memory. After you erase the
information, you cannot recover it.
Thanks
Good Luck
Don't forget to rate the solution
Jul 05, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
Cell Phones Logo
20 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
