Question about HP PSC 1210 All-In-One InkJet Printer
Paper jam i have a all in one and it keeps saying it has a paper jam but there is not one. i clear it and press enter and nothing happens and all the lights keep flashing. could someone please help me.
    Problem Solver:
  • 8 Answers
Try to remove all ink cart. and re install again...
Posted on Sep 20, 2007
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Says printing but nothing is coming out
If it says it is printing and no paper is being fed, and you are not getting any paper jam indicators, thats not good.
To get this reset you may have to do a RAM CLEAR. This will mean all documents in memory and all programming in the machine( date, time, quick dial numbers etc, etc) will all be lost, and will have to be re-entered.
If you want to try the RAM CLEAR do the following....
Press Program, *, 3.....display should say All RAM Clear ( enter/cancel) perform the Ram Clear press ENTER
To finish without doing the Ram clear press CANCEL.
Apr 27, 2010 | Muratec F320 Plain Paper LED Fax
Orange light flashing - won't print
have you got a reset button on your printer if so try pressing it down and holding for a few seconds put some paper in and try again
Mar 25, 2010 | HP LaserJet 1100 Printer
Cannon MP370, says clear paper jam, none seen
i know that happens to me check that everything it as it sould and resated
Dec 29, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
X2650. False Paper Jam indicator.
There are a few options for you. You can power it completely off for a few moments to see if that clears the error. During that time I would recommend using a can of air to spray out the inside of the printer. The sensors can get dust on them and make it appear that you have a paper jam. Also if there is a small piece somehwere the pressurized air will hopefully dislodge it.
Good Luck!
Oct 30, 2009 | Lexmark X2650 All-In-One InkJet Printer
Screen says open door clear cartridge jam, press enter. nothing is jamming it.
Open the printer and remove the cartridges and reinsert one at a time carefully. That should take care of it.
This can also happen if any of the covers are not perfectly in place or if there is a small sliver of paper or even dust being sensed by the printer. Open the covers and look for paper parts, slivers or dust and clean out if you find it. Then carefully make sure each cover is closed. Sometimes if you slam them shut the cover can distort enough to not close properly and is being detected as open. You also want to remove the paper trays and check there for jams and make sure the paper feeds correctly.
Oct 23, 2009 | HP PSC 2175 All-In-One InkJet Printer
Jamming problem
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
"Clear paper jam" error, but there is no jam!
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printing troubles
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Mar 24, 2008 | Brother HL 1440 Laser Printer
HP PSC 1210 All-In-One InkJet Printer Logo
115 people viewed this question
Ben Johnson
