Question about Citizen CLP-7202e Thermal Printer
Reset chip laser 315 s3cc921 - Citizen CLP-7202e Thermal Printer
TONER RESET PROCEDURE
No toner reset procedure , u need to replace toner chips ,else replace with oem toner cartrdiges
Jul 29, 2014 | Samsung CLP 315 Laser Printer
How do you replace the transfer belt on a samsung clp-315w?
Dear friends
we have solutions for OEM and compatible chip reset S3cc921
skype indianrefiller
Jun 06, 2011 | Samsung CLP 315 Laser Printer
Hi i refilled my toner cartridges for the Samsung CLP 315 and it wont print! Do I need to reset or something??
Hello
The toner cartridge also needs to replace chip on cartridge as well. When you get the first warning of low toner, refill the cartridge as http://www.youtube.com/watch?v=K0t6OfNYf6Q and you won't have to do complicated chip modding. You will get about 3 refills per cartridge before the printer figures it out though, then you will need a new cartridge.IF you don't want to have to mod or replace your cartridge chip, simply DON'T let the cartridge get to completely empty. If you do, the chip will activate and tell the printer not to use that cartridge, even if refilled? to full. then there is no other way to replace chip/cartridge.
Hope this helps if so do rate the solution
Good Luck
Jan 03, 2011 | Samsung CLP 315 Laser Printer
Toner exhausted error is showing after refilling.
A reset chip is available from several vendors that overrides the printer's internal counter. This reset chip is installed on the motherboard, either by hooking tiny wires around the contacts of an IC chip, or by soldering. This reset chip is becoming easier to find. Check out ebay and other online vendors.
good luck, and rate the solution if helped
Nov 27, 2010 | Samsung CLP 315 Laser Printer
HOW TO RESET CHIP SAMSUNG CLP 315
www.governmentsecurity.org/forum/.../post-19-1091705103.ibf
Aug 03, 2010 | Samsung CLP 315 Laser Printer
Refilling toner for Samsung clp 315
Dec 19, 2009 | Samsung CLP 315 Laser Printer
Toner exhaust yellow toner
samsung clp color leserjet printer writes this massage toner exhaust yellow toner. i have done the toner refil without the reset chips about two times now and i have been printing for some time now i get the message "toner exhaust yellow toner"
Oct 01, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-315 eats toner. Cartridges last almost
ean_inkrefills on ebay. Search on the terms "samsung clp 315 toner refill solution". Chip installs on the printer motherboard--installation is not overly difficult, but still not for the faint-hearted. I expect it voids the printer warranty. Ean gives good email support.
Aug 02, 2009 | Samsung CLP 315 Laser Printer
How to refill samsung clp 315 cartridge
you need cartridge chips for reset counter before refilling process
Jun 27, 2009 | Samsung CLP 315 Laser Printer
Refill clp-315
No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
Feb 21, 2009 | Samsung CLP 315 Laser Printer
Citizen CLP-7202e Thermal Printer Logo
93 people viewed this question
Top Citizen Office Equipment & Supplies Experts
jay kaye
jay kaye
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
