Ge washer model whre5260
Wash size shut off failed
SOURCE: GE front Loader Washer Door
the following link might help you out.Please do post your comments.
http://www.repairclinic.com/Parts?s=t-WBVH6240FWW+-%3d%3dc226&n=1&z=10
Posted on Dec 23, 2008
woodchuck789
  • 4070 Answers
SOURCE: the water does not shut off even after it reaches
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Posted on Sep 14, 2009
blueextc3221
  • 15935 Answers
SOURCE: GE Top Load Washer Shuts off during wash cycle intermittenly
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
  • 3 Answers
SOURCE: ge WASHER WHRE5260E shakes violently and makes
the cloths in the washer needs to be ballance... too much load on one side
Posted on Nov 14, 2010
FitzOriginal
  • 842 Answers
SOURCE: Admiral Capacity Plus Washer -
This is almost certainly the result of the fill sensor failing. intermittantly
Essentially, the sensor is a bellows device. A pipe is connected to the device and as water reaches the end of the pipe and advances up it, the air pressure in the pipe increases, inflating the bellows. As the bellows inflate, they press on and trip a microswitch inside the sensor and cut the power to the water inlet valve, stopping the water flowing into the machine when it reaches the correct, measured level according to the pressure in the pipe.
Take the top off the machine, if you look down the side you will see a (typically clear plastic) tube about the thickness of a pencil, connected to a circular device about the circumference of a coffee cup and about an inch to two inches thick.
This is the sensor. Problems with it may be:
It has come unclipped from where it should be mounted. The device is VERY sensitive and if it has slipped out of place, over or underfilling is common. (Reposition the sensor, hopefully you can see where it came from!)
The pipe that is connected to it has come off, so the air pressure that the sensor measures is not increasing as the machine fills (push the pile back on and all is well)
The machine has been subject to some trauma (Such as a very uneven load that has made it shake violently. The starting level of the water that is in the bottom of the pipe is now wrong and the pressure sensor is being affected. (Remove the pipe from the sensor, blow down the pile to get any water that should not be there out and then replace the pipe).
Posted on Jul 07, 2011
My knob oN THE START SWITCH SPINS AND DOES NOT ENGAGE
Sounds like a broken know try pushing in with some force or pull out with some force if both fail the know will have to be replaced
Sep 26, 2012 | GE WHRE5260E Top Load Washer
Runs and stops runs and stops just have to reset to run is electric board bad
On something like this several test will need to be made with a volt/ohm meter & inspection of the washers control board in order to determine what the problem is. Usually on this model the "control board is the failed component. Here is a link to the control board in case you need it.
Jan 25, 2011 | GE WHRE5260E Top Load Washer
Ge WASHER WHRE5260E shakes violently and makes loud noises during spin cycle
Nov 14, 2010 | GE WHRE5260E Top Load Washer
My GE WHRE5260E leaks out the bottom occasionally ,what is the problem
check the seal on your drain pump it is where it attaches to the motor
Feb 16, 2010 | GE WHRE5260E Top Load Washer
The water does not shut off even after it reaches the proper level it continues to run and it overfills and leaks out the bottom of the washer the clear hose is not clogged and we blow into it we can hear...
Sep 14, 2009 | GE WVSR1060A Top Load Washer
I have a GE Washing machine model WWRE5240D1WW. How do I get the top and the body off to work on it?
You don't remove the Top. You remove the Front. It is designed for front maintenace, the front pops off. Use a screwdriver on eaxh side about 2" down from the top.
Jun 09, 2009 | GE WHRE5260E Top Load Washer
What is the load capacity for the GE WPSE4200AOWW Washing Machine?
not sure exzakley ive repaired thousands of washers though.just dont pack the clothes in it.God bless,tom
Jan 01, 2009 | GE WHRE5260E Top Load Washer
Ge washer will not spin
is it leaving water inside,if so the pump in the bottom has something longed in it.it will be about the size of a fist with black or white hoses going to it
Nov 14, 2008 | GE WHRE5260E Top Load Washer
Agitator on washing machine
Hi thanks for your question . Yhe only reason you would want to take the agitator off would be to remove the tub .And thats tye only reason thanks for the question The appliancd doc
Sep 11, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
