Question about Watches
How to change time on a neff flava watch - Watches
Changed the battery, hands move slowly but doesn't keep time...help
There is likely something wrong with the gears and mechanisms inside.... you can contact the manufacturer and ask if others have had a similar problem, and see if they might have a solution. Other than that, you may just have to get a new watch.
Feb 07, 2016 | Neff Daily Sucker Blue & Black Analog...
How do i turn off alarm on my neff flava watch ?
Here is a YT video that is helpful for this question:
Neff Flava Watch SKU 7879816
answers can be found here:
How to change time on neff flava watch
Apr 13, 2015 | Neff Flava Green
Neff daily watch
Does it come with a battery in it? I've had watches where there was a little clear plastic tab you had to pull to allow the battery to make contact and the watch to run. If not, then all I can suggest is to but another brand of watch. Here's their web site link. At the bottom of the page is the contact link...good luck.
Front Page
Mar 29, 2014 | Neff Daily Watch - cyan/pink/black
I bought a Neff daily black analog watch at Zumiez about a month ago as a present for a friend. the problem is that the minute hand and hour hand do not move... you can move them to set the time but once...
I would take it into a jeweler and they will put a new battery in it for $4. If that fixes it all well and good, if not it cost you 4 bucks to prove it needs to go back under warranty.
Feb 06, 2014 | Neff Daily Sucker Blue & Black Analog...
Date does not change after 12:00 am
Does it change at all? You may just have to set the time 12 hours later so it changes at midnight not lunch time
Nov 30, 2013 | Neff Flava White Digital Watch
Neff recon watch time adjustment
I have the neff recon watch and didn't get the set up paper's for it so I can't set it. Can u send me the set up paper's?
uploadserror please enter an image url (gif, jpg, png).
Aug 12, 2013 | Neff Watches
Date is wrong on neff watch
Keep pressing mode until you get to where you get to edit the time and press the "light" button until there's a big number and that's the month and keep pressing the light button and you can edit the date and what day it is
Dec 16, 2012 | Neff Flava Watch Watches
I purchased a Nat. Geo. Dakota watch in past fall..It was impossible to set. Paid a watch shop to set it....now it won't change to daylight savings time...nor will it change time zones when I travel....
When changing time zones, your watch must be manually set for the new time zone you will be entering. This watch is not designed to adjust for new time zones automatically. Instructions for changing time zones can be changed using the directions found on pages 2-4 in your instruction manual. When changing to and from DST, your watch should automatically adjust for this difference with the next 24 hours after the change. If your watch has not adjusted, you may be in an area that is not receiving signal. Check if your watch has received signal by using the directions found on page 1 of your instruction manual. If your watch has received signal in the past and no longer is receiving signal, your watch may need to be serviced or exchanged. Please contact Dakota Watch Company Customer Service by email at customerservice@dakotawatch.com, or by phone at 1-888-459-0404.
Mar 08, 2009 | Dakota 2786-6 Wristwatch
Daylight savings time change without auto change in watch
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
Mar 10, 2008 | Casio G7500G-9V G-Shock Vibration Watch
Watches Logo
148 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
