Question about 98 - 02 Cummins Dodge 5.9 Turbo Diesel Engine Drop-in 24 valve
How to remove starter dodge diesel 1998 - 98 - 02 Cummins Dodge 5.9 Turbo Diesel Engine Drop-in 24 valve
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 113 Answers
Look underneath the engine should be 2 bolts and a couple of cables. Disconnect the battery first and remove the cables and bolts
Posted on Aug 08, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
No power to the fuel pump on a 1998 dodge diesel 3500
check fuses and relays, check for voltage on the wires that connect to the fuel pump.
Oct 11, 2014 | 1998 - 2002 Dodge Ram 3500 Diesel Fuel...
How to remove starter dodge diesel 1998 24 valve
first turn off radio then remove negative battery cable then you have to safely raise truck support on jack stands then remove starter electrical wires.remove starter bolts then remove starter.
Jul 15, 2013 | 98 - 02 Cummins Dodge 5.9 Turbo Diesel...
1999 DODGE DIESEL WONT START ON FIRST TRY TURN KEY OFF AND TRY AGAIN AND IT FIRES RITE UP AND RUNS FINE DOESENT MATTER IF ITS HOT OR COLD
Check voltage at starter (small wire) then check starter contacts..remove starter and take it apart. If they look chewed up replaace them.
Had the same problem and found burned contacts in 97 Diesel.
Feb 17, 2013 | Dodge Ram 3500 Cars & Trucks
I need a schematic for my 1998 Dodge pickup diesel
you have a direct short in the main starting line,ie the battery to the starter or the starter wires take a very good look and you will find/see the problem it will be a main red wire touching ground/earth.adrian,,
Jul 30, 2010 | 1998 Dodge Ram 2500 2WD
I need to replace the starter in my 1998 dodge dakota. Anything special I need to be concerned about?
just disconnect ur battery. remove 2 starter bolts, then disconnect wires attached to starter. install in reverse order.
May 23, 2010 | 1998 Dodge Dakota
I need to replace the starter on my 1998 Dodge Ram 1500 4wd 5.9l
Easy fix my friend.
1. Unhook the battery
2. Raise and support the truck on jack stands.
3. The starter is located on the drivers side at the front of the tranny.
4. Grab an 8mm and a 13mm wrench.
5. Remove the power wires from the starter.
6. Remove the starter by removing the top bolt 9/16 i believe and the bottom nut. Also 9/16 or 5/8.
7. Carefully slide it out toward the front of the engine.
8. Installation is the same as removal.
Hope this helps.
May 09, 2010 | 1998 Dodge Ram 1500 4WD
How to remove the starter in a 1998 Dodge Intrepid 2.7L engine.
I believe your have to remove the grill supports under the front of the car. Disconect your battery, ground(black) wire first. Then disconect your exhaust on the front of the engine to get to the starter.
Aug 09, 2009 | 1998 Dodge Intrepid
1998 6.5L diesel suburban won't start. Starter issue?
It sounds like it could also be the connection-check the wires going to it and the ground wire on the battery itself.
Mar 11, 2009 | 1998 Chevrolet Suburban
Starter
Here is AutoZone's online guide for your starter. If it's a matter of finding the bolts, this should help. It says there are only two unless you have a diesel. I haven't worked on a Durango myself, but have worked on other models that are just as frustrating. Good luck!
Feb 27, 2009 | 1998 Dodge Durango
98 - 02 Cummins Dodge 5.9 Turbo Diesel Engine Drop-in 24 valve Logo
138 people viewed this question
Top 6B Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a 6B Vehicle Part and Accessory Expert? Answer questions, earn points and help others
