Question about Honeywell Programmable Thermostat Heater
My air conditioner keeps blowing warm
Air conditioner blowing warm air and thermastat keeps going back to 81
  • 1,420 Answers
Help us by giving us more info. Is it a window air conditioner? Make and Model number? Have yu checked the air filter?
Posted on Sep 14, 2007
When i trun the thermastat on the fuses blows if i leave the thermastat in off position the fuses dont blow if i disconnect the red wire from air handler and the a/c it dont blow
Fault is on your unit , Thermostat is off , then most lilkly to unit , so no power, fuse will no blow ! Don't disconnect ,wires unless you know what you are doing.
Mar 16, 2015 | Heating & Cooling
The AC is on. Set at 61 deg. Keeps going back up to 81 deg. Blows cold for only 3 min. Any ideas?
You can try unpluging it to reset it .. this is a tough one as i not to certain.. But try that wait for about a munite nbefore you plug it back in.
Jul 19, 2011 | Haier ESA3109 WallWindow Air Conditioner
Goodman air conditioner is sometimes blowing out warm air. We've had this unit for 2 and 1/2 years. When we first moved in we had a problem with it not blowing out warm air in the winter. We had someone...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 30, 2010 | Heating & Cooling
Ok i have 40.00 dollars and need freon for my home central ac unit,how would i put it in the unit? can u please help me?ok it blows out warm air instead of cold air and the thermastat is saying 88 degrees...
Depending on where you live, you would need another
200.00 to buy the freon and another 60.00 to buy the
refrigerant gauges.
Turn the unit off outside, turn your thermostat all the way to cool and as low as it will go. Go back outside
and turn the power back on, The condensor fan and the compressor should both be on.
If neither one is on, or one is and one is not then 40.00 might be able to buy you a hard start kit
Jun 30, 2010 | Whirlwind FH-778 Air Conditioner
Air conditioner/furnace was working for the past few months. Came home today at it is at 81 degrees, although my set temperature was set at 72 degrees. Temperature is rising to 83 degrees and I can't...
Check outside breakers. Open up outside panel and see if contactor is pulled in. If so you have a voltage problem or a bad capacitor. Sometimes a wire burns off. So look for this. If you have a float switch on the inside unit it may be tripped. Stopped up drain. Russ
Jul 30, 2009 | Heating & Cooling
96 Rav4 air conditioner blows cold 10 min. then warm
you still got a leak,could be the ac hose,recharge again but this time w/dye so u can see if theres a leak,good luck keep posted..
Jun 04, 2009 | 1996 Toyota RAV4
Heater not working correctly
you might have a blocked heater core,the core looks like a mini radiater
Dec 17, 2008 | 1999 Dodge Ram
Refrigerator blowing warm air.
check the thermastat with power off remove one wire on the thermastat and read across the two terminals of the thermastat with an ohm or resistance meter if set to highest setting on the thermastat you should get a resistance reading if you don not the thermastat is vad
May 17, 2008 | Amana ARB8057CSL Bottom Freezer...
Heating & Cooling Logo
149 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
