Question about La Crosse Technology La Crosse C86234 Wireless Weather Station
Rain gauge not working on model c86234 - La Crosse Technology La Crosse C86234 Wireless Weather Station
Replace the glass reed switch on the circuit board as it is bad. You must be very careful to orient the replacement switch so that it closes only when the rocker arm is at the vertical position. This will take some work to get right. Use a volt ohm meter and set the Plus lead at the reed switch lead at the top of the board. The meter should show a closed circuit only when the rocker is at the top. Good luck.
Posted on Jan 16, 2014
Are there different types of rain gauges?
There are a few different types of rain gauges. Standard rain gauges, Weighing percipitation gauges, tipping bucket rain gauge, optical rain gauge and the aucoustic rain gauge. They each measure rain in a different and some of them interesting ways.
Dec 29, 2013 | Garden
Tip
How to measure rain fall when your rain gauge overflows
Most rain gauges that you will make at home will only measure up to one inch of rain fall. The problem with this is that if you live in a place where you will get more than one inch of rain your measurement if taken incorrectly will be very skewed. If your rain gauge has been constructed correctly you should have a fail safe in place.
When you construct a rain gauge you should have a measuring tube inside of an over flow tube. The meausuring tube will hold about one inch of rain fall, but when more rain falls the inside tube will overflow into the outer tube. To measure the excess rain fall you will follow a few simple steps.
Start by reading the inner tube of the rain gauge and then carefully empty the tube. Make sure that you don't pour out the water that has overflowed into the outer tube.
Once all the water for the measuring tube has been emptied carefully pour the excess rain water into the measuring tube. To get the most accurate reading try your best to not spill any water out, you can pour the water over a bucket to make sure that if you do spill any out you will catch it and be able to measure accurately.
If there is a lot of overflow you might want to measure a little bit of overflow at a time to get an accurate read. As you measure, write down the measurements and when you finish add up the values to get the reading.
The readings are done in inches so you have a reading that is 1.00 and has an overflow that measures up to .50 then the total read out will 1.50 inches.
on Feb 02, 2014 | Garden
What is a rain gauge?
A rain gauge is also known as an udometer, its an instrument that is used to measure rain over a period of time.
I need a manual for Rain Harvesting Pty Ltd TATG02 Tank Gauge Level Indicator
You can find one on this page:
http://rainharvesting.com.au/products/measuring-a-monitoring/tank-gauge
Jul 07, 2013 | Rain-X Rain Harvesting Pty Ltd TATG02 Tank...
My rain gauge is from England... how much does each line on the gauge measure?
on the standard NOAA rain gauges using the metric system, each line is 0.2 mm
Jan 28, 2013 | Garden
What are the most common types of rain gauges?
standard NOAA rain gauges are the ones you are used to seeing. there are also weighing precipitation gauges, acoustic gauges, optical gauge, and tipping bucket gauges.
Wind sensor not working
We are having the same issue. How did you get this resolved?
Oct 24, 2012 | La Crosse Technology La Crosse C86234...
I recently purchased and installed an Oregon Scientific Model WMR200A. The rain gauge worked for the first rain fall but it has not worked since. Today we probably got 3 inches of rain but it registered ...
Oregon Scientific has an FAQ webpage for your weather station:
http://us.oregonscientific.com/service/faq.asp?t=1&cid=2
There are several Q & As that are pertinent to your problem.
I hope this helped you.
Good luck from Detroit, MI.
Jul 19, 2011 | Vacuums
What does a simple rain guage consist of?
There are a variety of commercial rain gauges available on the market, however making a simple rain gauge is quick, easy and only costs as much as a plastic bottle. Chances are you already have everything you need to make this simple rain gauge, which is fun to construct, and interesting to use. Read on to learn how to make a simple rain gauge.
  1. Cut the top off of your plastic bottle. Cut about a quarter of the way down, to where the bottle begins to have a consistent diameter. Be careful to cut the edge as smoothly as possible, salvaging both pieces of the bottle.
  2. 2
    Remove the bottle cap and turn the top part of the bottle upside down, placing it into the bottom part. Connect the two halves with paper clips.
  3. 3
    Place the plastic bottle rain gauge in a location where it will easily collect rain without impediment from surrounding trees, plants or buildings.
  4. 4
    Help your rain gauge stand upright by placing it in a sand or gravel filled bucket. Simply make a hole in the sand or gravel large enough that half the bottle gauge sits into the pit. Use the gravel or sand to support the edges of the bottle gauge.
  5. 5
    Measure the amount of rain caught by your gauge by emptying the contents of the bottle rain gauge into a measuring cylinder.
Feb 07, 2011 | Home
La Crosse Technology La Crosse C86234 Wireless Weather Station Logo
225 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
Tom Chichester
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
