Question about Nokia BH-218 Bluetooth Headset
When I try to couple the BH-218 to my Garmin i press the ]as in the manual but only get voive prompt on or off, the coupling mode does not seem to function.
I have tried with the ear piece in and out of the cradle with the same result. The blue light that is supposedly to appear according to the manual, doesnt, is the unit faulty?
  • Nokia Master
  • 7,733 Answers
My guess is you don't have the headset in pairing mode. The instructions below are from the instructions for the BH-218"
Before using the headset, you must pair and connect it to a compatible phone.
1. Make sure your headset is switched off and your compatible phone is on.
2. If you've never paired the headset with a device, or you've cleared the pairings,
switch the headset on.
If you've previously paired your headset with another device, press and hold the multifunction button
for 5 seconds.
Pairing mode is switched on, and a blue indicator light starts to flash quickly.
3. Within 3 minutes, switch Bluetooth on in your phone, then set it to search for
Bluetooth devices. For details, see the user guide of the phone.
4. On your phone, select the headset from the list of found devices.
5. If asked, type in the passcode 0000.
When the headset is connected to a phone, the Bluetooth indicator light flashes
slowly.
You can pair your headset with 8 phones, but you can only connect it to 2 phones at
the same time.
With some phones, you may need to make the connection separately after pairing.
Tip: Can't connect the headset to a compatible phone? Make sure that the headset
is charged, switched on, and paired with the phone.
Posted on Jul 15, 2013
4 Suggested Answers
  • 44 Answers
SOURCE: I have a new cell
Search in headset manual for default PIN Code or try using your previous mobile security code or pairing code.
Posted on Sep 03, 2010
lexzy80
  • 943 Answers
SOURCE: Why does my Nokia X6 and Sony Ericsson X8 both are
you can log on to the website and check for the compatible devices and see if your phones are among the supported devices.
also, it could be that your bluetooth headset is faulty and as a result cannot be detected, you can try searching for other bluetooth devices using your phone and if it does find them, then you can confirm that your headset is faulty or broken.
at this point, you can send it back to the store where you bought it from and get a replacement or you can send it for repairs.
hope this helped you? please rate
Posted on Dec 22, 2010
SOURCE: Hi, guys. I recently bought a Nokia BH-505
Hi Bogdy_3003,
I see that you are having issue with your BT Nokia headset.
You mentioned that you are having issues connecting it to our PC.
You need to make sure that the Bluetooth settings on the computer is set to allow other devices to detect the computer to be able to get your Bluetooth Nokia headset working with your computer.
Look for the Bluetooth icon on the lower right side of the taskbar somewhere near the time then right click on it then select open bluetooth settings, it should open up a window for the Bluetooth on your computer then look for "Allo other devices to detect this computer" and put a check on it, click on Apply or OK, this should make your computer be detected by other BT devices such as your Nokia headset.
I hope this will help.
Have a nice day,
mvincentc
Posted on Jun 21, 2011
Pairing problem of nokia bh 111 with laptop
On my BH111 I just held pressed the turn off/on button for like 10 seconds. After 3-4 seconds it turns on with an upward chime tone, then after a couple of more seconds it gave some other sounds and it become visible on my Macbook.
Jan 18, 2013 | Nokia BH-111 Bluetooth Stereo Headset
I haven't used my Garmin GPSMAP 292 for a couple
Have you tried pressing Page + Power at the same time while starting the 292?
Seems like there is a well Kinoen problem with the auto locate locking in wrong position and IF you reset the past position memory by pressing Page + Power while Power up should fix the problem.
You still need approx 20min location time but its better than 12-24h.
Jul 27, 2011 | Garmin GPSMAP 292 GPS Receiver
On a trip, and suddenly, Garmin won't come on. If it does, once in a while, it stays on the first screen that says Garmin. I paid over $500 for this item and have only had it for 2 years. Is there...
There is a way to reset most Garmin GPS devices, however a model number would have to be provided to determine the method.
You can try one of these methods:
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press continuously on the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Or:
Turn off Garmin device. Press down on bottom right corner of the touchscreen and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Let me know if that works for you.
Jul 20, 2011 | Garmin GPS
My Garmin will not power up. We have hooked it up to the usb cable to our computer and it still does not come on
try entering maintenance mode~~
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Hack above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
~~ http://www.mydigitallife.info/2009/06/09/how-to-reset-garmin-nuvi-gps-device-access-maintenance-mode/
Mar 07, 2011 | Garmin GPS
Nokia BH-101 Not Pairing with Playstation 3
Consult user manual for how to put device into pair mode, then search under bluetooth settings on ps3 if prompted enter pin code 0000. If this does not work consult usuer manual for how to do a reset on the device, it should then automatically go into pair mode. From there search and pair.
Rylan
Dec 17, 2010 | Nokia BH-101 BLUETOOTH HEADSET
My garmin forerunner 305 turns off automaticly after a couple of minutes, and the battery is fully charge.
Try SW reset. Hold Mode and lap/reset for 10 seconds, then release and long press start until device restarts.
Should clean up default.
If not try hard reset, but you'll loose all data in device.
hold mode and start for ten second, device needs to off before.
Then keeping these, pulse press lap/reset.
You'll get a confirmation screen
Oct 04, 2010 | Garmin Forerunner 305 GPS Receiver
Trying to pair nokia x6 with nokia BH-214 bluetooth headset i need the code to pair them
You have to hold the button down on the headset controller for approximately 6 seconds until the little LED on it flashes blue very quickly. The X6 will see it and match a pair automatically. If you just switch the headset on and the light flashes green the x6 will ask you for a passcode ... it doesn't matter what you put in (it seems) even '0000' ....it won't match the pair. HTH
Reply
Sep 15, 2010 | Nokia BH-214 Bluetooth Stereo Headset
My garmin nuvi will not shut down. The screen is white. Is there a reset button on the unit?
In some nuvi models there is a reset button.But in some nuvi models there is no reset button.you have mentioned only garmin nuvi but not mentioned the model of the garmin nuvi.But still i will mention the reset button location of some garmin nuvi models.Hope that helps you.
The reset button/procedure for garmin nuvi models
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
above works on Garmin nuvi 200, 250, 360 750, 760 series unit. Garmin Nuvi 360 on how to perform the hidden reset function.
Reset button on the bottom of the nuvi backside.
Click on the link below to get the exact location of the reset button.http://www8.garmin.com/manuals/1512_SetupandGo!.pdf also check out this link too http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf Thanks. keep updated for any more query.you can rate this solutionand show your appreciation.
Jun 11, 2010 | Garmin GPS
I have a Garmin 396 that I use for aviation navigation. The 396 just suddenly became unable to find the satelites and therefore will not function. I tried to rebook by unplugging the battery for a couple...
I recommend either resetting the device or update the software. You can find software downloDepending on which model of Garmin GPS unit you’re using, thefollowing routine can reset the Garmin device to original factoryloaded settings, or bring up the Maintenance Mode with access to SystemInformation and View Diagnostics screen, where users can see variouslogs, and of course, clear all user data (reset to factory defaults) orclear Waypoints.
Power off Garmin unit. Press on continuously the uppertop left corner of screen and then power on the unit by pressing onceon the Power button. You should be prompted to clear all user data, orasked if do you really want to start up in maintenance mode. Press“Yes” to reset (warning: all data will be erased and lost,so backup before proceeding) or enter maintenance mode.
Turn off Garmin device. Press down on bottom rightcorner of the touchscreen, and then power on the GPS unit. You shouldbe prompted whether do you really want to erase all user data, or askedif do you really want to start up in maintenance mode. Press“Yes” to reset (warning: all data will be erased and lost,so backup before proceeding) or enter maintenance mode.
Trick above works on Garmin nuvi 200, 250, 360 750, 760 series unit.In fact, there is a video demo by user of Garmin Nuvi 360 on how toperform the hidden reset function.
Note: If entering maintenance mode, it’s also possible to perform master reset by selecting clear user data option.
Once the device has been hard reset, user have to perform the set upprocedure again upon start up. Note that erase user data command onlydelete data in the Garmin unit’s memory that isn’taccessible to the user when the unit is connected to computer. Thecommand does not erase .gpi or .gpx files loaded (if your .gpx filescontain any waypoints then they will automatically be imported intoFavorites), nor will delete any MP3 music, JPG photos or any otherfiles that have been stored on the GPS memory card.
Once the Garmin GPS unit is reseted, remember to place the deviceoutside where there is a clear unobstructed view of the sky for 15– 30 minutes in order for it to requires fix to GPS satellites.
Unfortunately, even if you perform master reset on Garmin GPS unit,it does not reset Garmin Lock security feature, which password-protectmost Garmin electronic devices to deter theft. If you forget the PIN orpassword unlock code to unlock the Garmin unit, the best solution is tobring it to Garmin to get unlocked. “Secure Location” doesnot unlock a locked Garmin unit either as it’s only a temporaryfix as when it’s turn on outside the security location, thedevice is locked again.
ads on the manufacture's website.
Nov 15, 2009 | GPS
Touch screen does not respond
Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
Step 3. Select the yes button.
Step 4. Enter your PIN if enabled.
Step 5. Main Maintenance Mode screen should have 4 selections:
System information
View Diagnostics
Clear User data
Clear Waypoints
Step 6. After some selections the unit should reboot and you check to verify unit after rebooting.
Feb 25, 2009 | Garmin Nuvi 300T GPS Receiver
Nokia BH-218 Bluetooth Headset Logo
46 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
