Question about Garden
Husqvarna gth2548 fender cracked where seat mount is
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: What is the length of the primary mower belt for a
Many of the parts you can just drop the prefix and use the Sears /AYP #
So, look at the hood sticker or in your manual for the Husq#. 532 18 08-08 becomes 180808 which is a common Sears belt for their secondary belt on the newer 48.
OEP shows as a 5/8 X 89"
The primary for these 174368 (Engine to deck)OEP shows 5/8 X 90.
Best to get the oem if you can. Never tried aftermarket on these.
Also found THIS USEFUL INFORMATION.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 05, 2009
  • 86 Answers
SOURCE: gth2548 belt diagram and steering trouble
Go to searsparts.com type in your model number it should show your diagrams and parts for your mower
Posted on May 12, 2009
  • 95 Answers
SOURCE: engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
Posted on Jul 31, 2009
How to remove fuel tank on 48 inch husqvarna riding mower
pull the rear seat/fender assy... the floor boards ( where your feet sit ) have a couple of bolts, then the seat springs have a couple of bolts... a couple of handles might have to be removed...
Aug 26, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My husqvarna gth2548 cut off while cut yard and will not start back is It safety related issue under the deck?
I would check for a loose connection at the seat switch. If these are not fully plugged then shorting strip will ground out the engine.
Aug 11, 2014 | Garden
The fender nut for mounting the seat has fallen off
Hi Anonymous, take a long zip ty and slide the fender nut over it then thread the pointy end of zip ty through the rear fender seat nut hole and pull up aligning the index nub with the one in the fender hole, attach the plastic c-clip and your good to go. Good luck.
Mar 12, 2012 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Gth2548 25hp 48" - bolt
Hi hoofprintsfa,
Welcome to fixya!
Here is the website for your manual: www.mymowerparts.com/pdf/Poulan_AYP_1/logt25h48a_e.pdf
Copy and paste this address into your web browser and the manual will be ready to download for you.
Here is a website where you can get parts for your tractor. It includes a parts diagram: http://www.partstree.com/parts/?lc=&mn=Gth2548
Hope this helps. If it does, I'd appreciate your vote. Keeps me working here.....
Thanks,
Handie Andie
Jun 21, 2011 | Husqvarna Garden
GTH2548 drive spring broke and I replaced it. Tractor would not start. Replaced battery, start switch, seat switch and PTO switch. Tractor will now start and runs well. However, when PTO switch is...
yes when the belt broke it grabe the wires that goto the cluch frome the pto switch and thay have bar spots on them and are grounding out i just done one that was doing the sam thing all you have to do is fix the wires and that should fix ya up thanks for your time mickey
Sep 08, 2010 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Blades will not engage on Husqvarna riding mower.
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine dies when clutch brake released on husqvarna gth2548
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Gth2548 belt diagram and steering trouble
May 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
