Question about Holmes Products Heating & Cooling
Air lock cooling system
How do I stop my fan from rotating?
  • 7,733 Answers
You can not stop it.It run in auto mode.
Posted on Jul 16, 2013
Why does the cooling fan start and stop?
it depends on the model of the projector!
The projector has an internal temperature monitoring system to check the heat generated by the projector lamp. When the heat is at its maximum levels , the cooling fans rotate the fastest and when it comes under control , the speed lowers!
if your projector does not goes into thermal shutdown then it means everything is normal and u do not need to worry!
also ensure that the air inlets and out lets should not be blocked to ensure smooth cold and hot air flow from the projector!
Jun 05, 2015 | Office Equipment & Supplies
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
I cant remove my fan its an intel D34223-001
Intel D34223-001 is fan and Heatsink assembly for Intel Socket 775. Following are the videos about removing and installing this fan
REMOVING FANINSTALLING FAN
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 29, 2011 | Intel (D34223001) CPU Heatsink Fan
V6420us - noisy fan how do I gain access to the fan for cleaning? Thank You.
Cleaning the fan won't stop the noise, it may help a little - the little bearing has worn having rotated millions of times.
Try a can of"air duster" spray to blow the muck away from the fan area.
You may need a new fan - the part is pennies but the labour will be more!!
Feb 25, 2011 | Compaq Presario Fan
Lg art cool beeps but doesnt start
Indoor fan motor mechanism locked. Or indoor coil sensor defective. Rotate manually f.m. If easy to rotate, replace sensor. If not, replace bearings or motor.
Jan 13, 2011 | LG Art Cool LA181CNW Split System Air...
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
IBM projector needs a fan replaced but can't find exact model
A locked rotor indication will stop the rotation of the fan completely, however if the fan is still rotating then it wont show "locked rotor signal". If the projector is still under warranty then locate their nearest service center and get it rectified..................sodeep
Jul 31, 2009 | Computers & Internet
When I turn on my goodman A/C, the fan in the outside unit rotate
Bad capacitor or bad motor does the fan blade turn freely? if it does probably capacitor if it turns slow or hard replace motor. Good luck Tom
Jun 26, 2009 | Goodman CKL42AR42 Air Conditioner
My computer is laptop ibm thinkpad r40. and the problem is the cooling fan cant work. how to solve this problem?
hi,
before replacing the cooling fan try to spray some air using compressed air can(no other thing), as sometimes there is dust that is stopping the cooling fan to rotate.
further queries are welcome
if you find my solution helpfull please do rate me
Feb 21, 2009 | IBM Computers & Internet
Intertherm model P853A5 older style AC unit fan will not start to rotate when thermostat control set to cool.I have a feeling that it might be the electric motor. I removed the screen and rotated the fan...
This is most likley the capacitor. Be very careful when changing it out!!!!! Make sure to use an insulated device to discharge it first before touching it!!!!!!! To discharge it place insulated device across the two spade connectors on top.
Aug 26, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
Top Holmes Products Heating & Cooling Experts
paulcarew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
