Question about GE Freezers
Deep freezer model fh25dsd
Stoped working i plug it in it clicks on the back off
  • GE Master
  • 4,654 Answers
You need to unplug the freezer because the compressor is getting hot and the reason the compressor is trying to start but cannot. This clicking is possibly a defective=> WR7X225 Start Relay or a defectve WR62X10058 Run Capacitor If you have an OHM meter you can test the compressor windings. as in the instructions here=> Unplug the freezer and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Have you already solve this problem?
Posted on Jul 26, 2013
Freezer won't turn on
GIVE IT TIME SO THE THE SYSTEM COULD STABILIZE IT SYSTEM FOR A FRESH STARTUP. OR HAVE CHECK TO ITS OVERLOAD UNIT THE COMPRESSOR MOTOR.
Sep 12, 2012 | Kenmore Freezers
Model ufp19n-lx2 freezer will freezebut motor run all time and hot
its very likley that the thermostat has stoped working in the on posion and the freezer is running 24/7 this wont do the compressor any good at all, change the thermostat asap,
Nov 22, 2009 | Frigidaire Freezers
Upright Deep Freeze Stopped Working
the compressor relay is gone For a few dollors you can still save it.
Mar 27, 2017 | Kenmore Freezers
MAKING A LOUD CLICKING SOUNDS
Hi, I am not familiar with this model but the noise sounds like a relay clicking at the compressor. Is the sound coming from the outside in the back?
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Haier 9.1 cu. ft. / 258 liter Upright...
DEEPFREEZER
The best you can do is ensure that the compressor area and fins are not clogged by dust and such. But don't mess around long, call a repair man to fix your freezer if cleaning doesn't help. Prob cheaper than replacing your spoiled food.
Oct 24, 2008 | Freezers
My kenmore upright freezer quit working after power outage
is there any lights on in the freezer? try plugging the freezer into an outlet you know is working. there is no "reset" on the freezer so if lights are on and it still isnt working it could possibly be stuck in defrost or the thermostat could be stuck in the off position.
for the defrost problem: pull freezer from wall and look in the compressor area and you will see a control under the unit left of the compressor. using a flat blade screwdriver advance the timer clockwise a few clicks and it will probably come back on. if that doesnt work lets check the thermostat.
thermostat stuck: this is easy but you need to check def timer first. using the handle of you screw driver tap the thermostat knob firmly. if the contacts are stuck open when you hit it the contacts will release and the unit will come back on.
hope this helps..
Dec 13, 2007 | Freezers
Freezers Logo
74 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
