Question about AEG 23 in. Favorit 50750Vi Built-in Dishwasher
Aeg favorit 60850 wont turm on
My dishwasher wont turn on (no lights or anything). I tested the power wire is ok and properly connected. Seems like a fuse problem. Is there a fuse? where is it located? Thanks!!!
2 Suggested Answers
SOURCE: AEG Favorit dishwasher fault
check time delay function - press til '0' appears or repeatedly til all time delaying diodes do not light
Posted on Jan 17, 2009
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Wont heat or dry dishes
USUALLY THER IS A SENSOR ELEMENT FOR HEATING TEMPERATURE MAY BE FUALTY ..
TRY IT ..
THANK YOU
Jun 14, 2009 | AEG 24 in. Favorit 40630 Free-Standing...
AEG Favorite Compact 525. The pump runs continuously even when the on/off button is pressed. Tho only way to stop it is to turn the power off at the socket/plug. any ideas
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak)
Mar 10, 2009 | AEG 24 in. Favorit 40850 Free-standing...
Dishwasher keeps cutting out
Has the door got heavier recently?
Mine had a spring break which fell onto the electrics and shorted them. Unplug and empty it, then tip it up to see if you can see a loose spring. If it is then replace or re-fit the old spring, I have posted instructions and pictures here:
http://www.howtofixanything.co.uk/howto-260.html
Jan 24, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Aeg dischwaher model oko favorite
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Feb 20, 2008 | AEG 23 in. Favorit 50750Vi Built-in...
Open Questions:
AEG Oko_Favorit 50750 - 2 beeps Hello. I have tried to find a solution to this in the manual and online, but have had no success. To start, this is a built-in dishwasher, and i will explain the button configuration, as that seems to change from model to model, and it is different from the button layout shown in the manual. Mine has a physical On/Off switch (click type, not a soft button) on the far left, and then grouped on the right are: Rinse & Hold, Intensive, Normal, Bio, Quick Followed by an On/Off light (plus, to the left of Rinse & Hold is a Salt light) Here's what happened - I put salt into the salt container (water naturally flowed out of the container as i filled it) -I put dishes into the dishwasher, detergent into the right place -turned it on, pressed the Normal button (the On/Off light was solid, as was the Normal light) -closed the door. The dishwasher started the cycle, but after about 10-20 seconds, there was a warning tone: 2 beeps. i opened the door and the Normal light was flashing continuously. Tried: -turned off, then on (using the switch) pressed Normal, but the light on the Normal button was flashing. closed the door, and the same problem occurred (starts, then 2 beep warning) -checked the drain pipe, and the bottom of the dishwasher for blockages. (since the manual says that 2 beeps = blockages) -turned off and on (at the mains) then turned on dishwasher, choose Normal (but the light was still flashing, and the same 2 beep error happened shortly after starting) -played around with button combinations. By holding down Rinse & Hold and Normal and turing on the machine, i get every light to light up, with a long solid tone. then the Salt light flashes rapidly. By then pressing the Intensive button, the Rinse & Hold light will flash, and each press of Intensive moves the light down the row (Rinse & Hold, Intensive, Normal, Bio, Quick) and then back to rapid flashing Salt. Also, when the cycling of lights gets to Normal, i can hear a relay click, and then it clicks again when advancing to Bio. *NOTE* I have no idea what this sequence is doing! I can't find it documented anywhere. Thanks for your help!
Sep 12, 2012 | AEG 23 in. Favorit 50750Vi Built-in...
See all AEG 23 in. Favorit 50750Vi Built-in Dishwasher Questions
AEG 23 in. Favorit 50750Vi Built-in Dishwasher Logo
81 people viewed this question
Top AEG Dishwashers Experts
paulcarew
Mike
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
