Question about Bush DVD142RC 14 in. TV/DVD Combo
Jammed dvd the dvd is jammed inside and I can't get it out
    New Friend:
Do the following having device unplugged. Unscrew and remove the metal top. Unclip the front plastic cover. Unscrew DVD drive and disconnect it from the motherboard. Remove the DVD drive and turn it upside down. On its black case there are white protrusions from tray mechanism, within the guides grove. Slide them from right to left and tray gets released. My unit got jammed because my baby boy pushed the tray inwards. The belt powering the tray mechanism slipped. I put everything back in place and got the unit operational again.
Posted on Mar 23, 2014
    Genius:
  • 1,139 Answers
Open up the unit. Find the DVD carriage you might be able to extract the DVD this way, but if you are not find the DVD carriage load and umload motor and manually turn it. This will eject the DVD.
Posted on Sep 18, 2007
  • Nenad Jovanovic
    Nenad Jovanovic Mar 23, 2014
SOURCE:
My Toshiba DVT80KB won't select the DVD or eject it.
Well...there's a slight chance that your dvd got jammed or stuck inside thus it doesn't allow you to eject or use it.Here's a link to solve your jammed dvd Hope it helps :D
Sep 18, 2014 | Televison & Video
Jammed dvd player
Sounds like there is a disc stuck inside. Try undoing screws all around side of player and take off cover (make sure this dos'nt void warranty) Find disc and reverse procedure.Hope it helps.
Nov 26, 2013 | Televison & Video
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
Tv/dvd combo by poloroid 19
DVD units are rarely worth fixing considering the low cost to just replace them.
Someone would have to open it up and see if something is out of position or jammed inside the unit---shop I work for gets 5 dollars to open and remove a disc---if just a jam inside--sometimes once the disc comes out the unit works again----do not pry or force it to get it out.
to add information or ask a question use the "make a comment button" on this page.
Mar 26, 2012 | Polaroid Televison & Video
Built in dvd player wont work on viore model lcd26v37hau
The player has failed, i suggest you replace it with an external player, they are dirt cheap.
Mar 23, 2012 | Viore 37 Class LCD HDTV
My dvd player suddenly stopped working. It won't
Sounds like the disk acceptor motor or ejector is jammed, from the iteam listed above this is a combo unit. If you inclined you can go inside and check the enjector unit it may need to be repaired.
Now if this is under warranty you may want to take it in. Even out of warranty would be a execlent option. For any tv repair man to fix this would be $120 parts only labot your looking $35/hour time spend on this 1.5 hours..
But it sounds liek you got a jammed ejector unit and that you will need to go inside. I would not call this work for a end user because there is unwanted voltage and what not inside. So you might for a temp fix get a dvd seperate unit and hook it up to the video inputs on the unit for the temp fix.
Thanks please do be considerate and leave you postive feedback and ratings.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 19, 2010 | LG 23LX1RV 23 in. TV/DVD Combo
Why doesnt the cd/dvd stay in the VALOR player?
The dvd drive coud be jamming on something inside, or the dvd tray belt could be slipping or the disk could be jamming on something inside which is preventing the draw from sliding all the way in.
jon
Aug 10, 2009 | Valor Televison & Video
Won't open and have dvd inside
well if they both dont open its due to the players little gears there either jammed,boken,or just plane need replacing try opening the player and moving the tray with your hands back and forth and try losening the little gears its should work
Apr 15, 2009 | Philips Dvd Video Player
Dvd jam
Using a small needle their should be a hole in the front. This is the safety eject hole that will open the drive 99% of the time. Replacing the drive is just as easy. remove the few screws on the bottom of the laptop nearest the drive and grasp ahold of the bay and slide it away from the computer....hope this helped some....
Kevin
Jan 31, 2009 | Akai LCT3201TD 32 in. LCD Television
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
Bush DVD142RC 14 in. TV/DVD Combo Logo
273 people viewed this question
Top Bush Televison & Video Experts
Vitally Alcher
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
