Question about GARDENA Water Timer
I need manual anzin water timer - GARDENA Water Timer
How to set time on Yardworks two zone water timer
Copy following link to access manuals for each brand of water timer on market 2013:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Yardworks does not have website, manuals or warranty claim procedure.
Instead, yardworks repackages other brands of timer, generally water timers, such as orbit or melnor and raindrip. And sometimes repackages other brands of outdoor timers.
Recommend folks stay away from timer-repackagers such as Yardworks, Timex, First Alert, and buy brand names that have clear customer resources.
Jun 05, 2013 | GARDENA Water Timer
Need instruction manual for orbit sprinkler timer model 57196
Copy following link for Orbit Sprinkler timer manuals
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=01&Type=Timers
Copy following link for various brand name sprinkler timer manuals, including Nelson, Melnor etc if you need new timer
Sep 10, 2012 | Hardware & Accessories
Ringgrip timer manual
Raindrip water timer?
Copy following link to identify many different water timer brands and product manuals for each.
If you do not have water timer, then add a comment and carefully describe the timer in detail.
Aug 31, 2012 | Hardware & Accessories
Need to known how to set the timer do not have a manual we have the VIGORO deluxe water timer, they are about two years old.
I do not know how to set the timer, but can offer possible source for manual.
VIGORO timers can be same as Melnor:
Match up image with your timer and then download manual.
Water timers last 1 or 2 seasons. There is no repair for broken water timers.
http://www.melnor.com/instructions.php
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Hardware & Accessories
Not a gardenia timer. It is a verve digital water timer (B&Q). There were no instructions in the box.
Verve water timers might be Melnor:
Open following link for manuals.
Links to other water timer manufactures and manuals are found on following link:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Aug 11, 2011 | GARDENA Water Timer
I am looking for a battery water timer that does not need pressure to operate. Just gravity. Any ideas?
Google search: 'battery operated timer' and 'battery operated hose end'
Smarthome shows the Orbit: and has manual:
http://www.smarthome.com/31035/Orbit-57860-Battery-Operated-Sprinkler-Timer-with-Inline-Valve/p.aspx
The manual says 'turn down water pressure.' It looks to me like this timer opens and closes the valve with or without water pressure.
Sounds like it would be perfect timer for above ground cistern where gravity cause water to flow when valve is opened.
Amazon shows battery operated hose end, but doesn't show manual:
Hose end timers are not going to have a pressure gauge.
http://www.amazon.com/Hose-End-Battery-Operated-Timer/dp/B0001O0DXO
Apr 18, 2011 | GARDENA Water Timer
Gardena Computer # 2010
Gardena timer is not identified.
Most water timers use 9Volt battery, but Gardena timers have up to three different model numbers for each timer.
Possible Gardena manuals are found on following link:
Jun 21, 2010 | GARDENA Water Timer
GARDENA  Water Timer Logo
19 people viewed this question
Top GARDENA Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Bill Boyd
Are you a GARDENA Hardware and Accessory Expert? Answer questions, earn points and help others
