Question about Frigidaire FAA085P7A Wall/Window Air Conditioner
What type of freon this AC need - Frigidaire FAA085P7A Wall/Window Air Conditioner
What type of freon do i use in a 2000ford focus 2.0L DOHC
YOUR CAR USES 134 a FREON. THERE SHOULD BE A STICKER TELLING THE TYPE AND HOW MANY OUNCES.
Apr 03, 2016 | AC Cars & Trucks
What type of automotive refrigerant does my 1997 Isuzu Rodeo take for the AC?
You need to have the leak repaired first
Be responsible & don't polute the atmosphere
with refrigerant
You need that done, by trained personal at a repair shop
May 21, 2012 | 1997 Isuzu Rodeo
I want to know wat kind of ac freon my expadition
It uses the 134 A which is a replacement for freon, but is not freon. It is supposed to be more environmentally friendly, but is not as efficient when it comes to cooling as the old Freon 12. It is illegal in the US for you to have freon in your possession, only authorized shops are allowed to have it and install it.
Jul 25, 2010 | 2003 Ford Expedition
Type of freon is used in the 97 Sentra A.C.
The sentra uses 134A freon. Happy hunting!
Oct 29, 2009 | Nissan Sentra Cars & Trucks
Why type of freon goes into a coleman AC, 1994 Fleetwood Country Villa?
After some searching it sems to use R-12 freon. It is getting a bit hard to come by and you have to be licensed to purchase it.
Jul 06, 2009 | Coleman Mach III Air Conditioner
Not cooling
your system needs to be cleaned out and converted to r134 or you can try a r12 substitute
Jun 19, 2009 | 1993 GMC Suburban
What type of freon my ac uses
R-22, if it were R-410A then it would have a pink sticker on it near the service ports. You would know for sure.
Mar 24, 2009 | Weather King 12AJA4801AH Air Conditioner
Ac woes
When you open car in morning is there a strange smell in it? You can check ac pressure with a tyre gauge should have a filler looks like a tyre valve near ac unit under bonnet check if it has pressure if not you have a leak and need to find and fix that befor regas. If leak suspected (you got not preasure in unit) get ac regasser out and tell him/her you think it maybe leaking and if passenger floor wet and your system still uses freon good chance you have a leak, they should dye the gas and the leak will become very obvious very fast once car started and ac turned on. But if you use freon you may not be able to regas depending on the laws in your neck of the woods. Here in australia if your useing freon and you need to regas you have to change a fair bit to use a legal gas which depends on type of refrigerant unit installed.
Jul 26, 2008 | 1997 Dodge Ram 1500 Club Cab
Frigidaire FAA085P7A Wall/Window Air Conditioner Logo
15 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
