Question about Dryers
Santa e70469 ceiling fan wiring diagram
The pull switch has a gray wire leadng from slot3 which was disconnected from another set of wires in housing. I just need to know where does the wiring from slot3 on the pull switch connects to in housing box
Bgillespie
  • 89 Answers
SOURCE: wiring harness diagram
I need model number ...
Posted on Dec 17, 2007
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
jsrock516
  • 5911 Answers
SOURCE: WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Posted on Oct 16, 2008
SOURCE: pull switch wiring schmetic
Call an electrician
Posted on Feb 12, 2009
  • 235 Answers
SOURCE: Need a wiring diagram for a HamptonBay ceiling fan pull switch
Black is hot-white is neutral-blue is your light kit and goes with the black- yellow? should be a green for ground.
Posted on Jun 30, 2009
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Ceiling fan model 1660
Always write down which color wire goes into which slot on the pull chain switch before removing it. All I can tell you is the black wire usually goes into the L. The others you'll have to play with. Also, just because the switch looks the same on the outside doesn't mean it's the same on the inside.
May 26, 2013 | Dryers
Chain on a JInyou E70469 3 speed fan switch broke. need to replace switch
I have this exact Jin-You E70469 switch. Forget a replacement unless you drop about $20 on ebay. Westinghouse replacement switches did *not* work for this type of switch. Here's the solution that worked for me: CUT THE POWER and test before you touch anything electrical. 1) Diagram the wiring configuration of the switch noting where things go---take pictures. 2) Take out the wires that connect to it. Use a paper clip to spread the clips to pop them out. If you have any wires that come out and back in the switch itself, you can leave them attached. 3) See those pins that keep the housing together? Get a drill bit---or Dremel tool---just slightly bigger than the bottom of the pins. You're going to drill off bottom/rolled over part of those pins. Take it easy. LEAVE THE PINS IN. Do not take the pins out. With the bottoms of the pins ground off gone, now take off the nut that's threaded onto where the chain comes out. Now, carefully pry apart the bottom of the housing. Take a picture. Notice the position. Notice the position. Now, pry the little closure carefully just a little and replace the chain. Put the spring back exactly how it was. NOTICE the little finger in the bottom cover where the spring catches to snap it back. Put the bottom housing on. Holding the whole thing together, try the switch. If it doesn't recoil, pry it apart again, and adjust where the spring catches. This part will annoy some of you. Test again. If it pull ans recoils, you've got it. Put the nut on. Put electricians tape around the housing---don't cover any inputs. Re-insert your wires according to what you had. Put back together.
Mar 22, 2013 | Westinghouse Electric Westinghouse...
Need a santa e70469 switch
Pull Chain on Bottom
L 1 2 3
Upper Yellow Jumper Pink Grey
Lower Orange - Jumper Black
Santa E70469
SwitchCo part # 01
or
KensElectronics.com part # ZE-208D-01
z
Apr 23, 2012 | Hunter Dryers
I have a ceiling fan switch (Westinghouse 77075) that was broken, so I do not know where the wires (black, gray, yellow and purple) went. The speeds are black+gray+yellow, black+gray+purple, and...
I can offer resources:
1) Test switch that was removed, and test for hot connection to narrow down options.
What speed was fan stuck in when switch was removed? Let's say medium speed.
Which connection at fan is hot? Use voltage tester to find hot connection at fan, and match that up with wire-color on switch that was removed.
One and only one wire on 3-speed fan switch connects to hot. And the hot wire is the only wire that connects to each other wire as switch cycles through pull-chain sequence. All pull chain switches follow same sequence: off, low, medium, high.
Let's say old switch was stuck in medium, and you know which color wire connects to hot.
Test switch with continuity tester to see which wire(s) have continuity with hot wire: some switches, it will be 2 wires, and other switches it will be 1 wire. Match where wire(s) were connected, and map that to tests on new switch.
2) Open following link for illustrations and some other links.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Sep 16, 2011 | Speed Ceiling Fan 3-speed Switch By...
Wiring diagram for a 3 way ceiling pull switch.
These fans are manufactured by a number of overseas companies and sold exclusively by Home Depot. They do not have a standard color code for the fan switch. What you can do is turn off the power, keep the white neutral connected. Then using the black power wire fro the ceiling, take one of the switch wires and connect to that black, turn the power on and observe the speed .. low mark it 1, medium mark it 2, high mark it 3. Repeat untill you have identified all the speed wires. Then connect these wires to the 1,2,3, terminations of your new switch
Questions?
Please Vote !
May 29, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan capacitor hook up problem. I have a 3 speed fan. 4 switch. A 3 wire capacitor - CBB61. Kids lost wiring diagram. Any which way I try to wire it up only one of the speeds works. Any wiring...
The reverse switch on my Hampton Bay ceiling fan didn't work. I cut the 6 wires; 1 white, 1 gray, 2 pink, 2 yellow. Here's what I did. Removed reverse switch. Had 6 wires white, gray, 2 yellow, 2 pink. Connected gray to yellow, connected white to pink and fan runs fine. Is this OK? I do not need to reverse fan. It's been running for 1 hour now with no problems. Don S.
May 15, 2010 | Dryers
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Dryers Logo
593 people viewed this question
Top Dryers Experts
