Question about Microsoft SQL Server 2005 Standard Edition
SQL query to change date and/or time format
Can I do a SQL query to change the format of how the date (& time in a different field) is displayed before I pull it back into my VS 2010 .net reports? I just want a short date (& short time). Can someone provide an example? Thanks for any assistance.
    Problem Solver:
  • 16 Answers
The function you're probably looking for is CONVERT. Here's an example (101 applies the format "mm/dd/yyyy", 108 applies "hh:nn:ss"):
SELECT CONVERT(varchar(10),getdate(),101) as JustDate, CONVERT(varchar(8), getdate(), 108) as JustTime
Results:
JustDate JustTime
09/24/2013 13:13:56
(1 row(s) affected)
Posted on Sep 24, 2013
dbarchitect
  • 150 Answers
SOURCE: Help me..
It needs to be in the format "yyyy-dd-mm hh:mm:ss:nnn". The BETWEEN keyword must include the time as well. so if you want from DTPicker date of "2007-09-01" and "2007-09-10" it will literally be this "2007-09-01 00:00:00.000" and "2007-09-10 00:00:00.000" thus not including any of the day for the 10th. If you want the 10th, then you have increase Date2 + 1 day to be "2007-09-11 00:00:00.000".
You should always remember that dates include the time.
I like to use the >= date1 and < date2. It's a little more forgiving.
Posted on Nov 24, 2007
SOURCE: Connecting of SQL Server and .net
winxp
Posted on Jan 14, 2008
mcc99
  • 51 Answers
SOURCE: Microsoft Access Query
Your date form is what it wrong. In order to use dates in Access with a BETWEEN function clause the values have to specifically be dates.
You can create dates in literal strings using the # sign to bound them, as in:
Select DISTINCT [ActivityDate] between #1/1/08# and #12/31/08#
#....# tells Access to treat this literal string as a date.
If you are using non-literal values, such as a parameter handed into the query, which would then be a variable, you can't use #some_variable# to cause Access to view it as a Date since #...# is for literal values only. To convert (also called "casting" a variable), use the CDate function. CDate likes to know what format to expect the string to come in though so it helps to pass that along, as in:
Select DISTINCT [ActivityDate] between CDate(begin_dt_string) and CDate(end_dt_string)
Remember the date string you pass into CDate has to be readable as a date by CDate. So make sure you pass in something that it can handle (use the IsDate() function to check to be sure so you can avoid a runtime datatype casting error). If your locale is US, then passing in x/y/z it will take for MM/DD/YYYY. If Europe, it will take it as DD/MM/YYYY. So keep that in mind.
To convert out of a date, use the FORMAT() function. That is how you get a date data type value to become a string value.
More fun reading:
http://www.techonthenet.com/access/functions/datatype/cdate.php
http://www.techonthenet.com/access/functions/advanced/isdate.php
http://www.techonthenet.com/access/functions/date/format.php
Hope this helps!
Posted on Feb 23, 2008
robjac
  • 109 Answers
SOURCE: Conditional Formatting doesn't work until I select the item
the mouser is equip with shortcut of any of program by using right click pointing to item.
Posted on Oct 18, 2008
SOURCE: Running SQL queries on Excel
Another way to do it is to use the SQL Drill freeware Excel addin (http://www.sqldrill.com)
hth
Posted on Apr 21, 2009
How do you change the time on a dymo datemark
Hi there!
Here's what you can do"
1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
Note: The unit will revert back to normal display if no other key is pressed for 10 seconds
2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print..
Hope this helps!
Vikroks
Mar 29, 2011 | Dymo DateMark Date/Time Stamper
How do I set date and time?
  1. To set the current date and time, press and hold down the SET/EDIT button for 2 seconds, let go and the Month (M) and Day (D) indicators will start flashing.
  2. While the Month (M) and Date (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format, press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR and MINUTE fields. The field that is currently active will start flashing. To change a field's value press the LOCK button, each stroke of the Lock button moves one value up.
  4. Once you are finished setting the Date and Time press the SET/EDIT button to return to normal display.
Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189, and back up to the current year. Be cautious when setting the year
Resource 1: Dymo Date Mark Electronic Date/Time Stamper Manual
Feb 17, 2011 | Dymo Date Mark Electronic Date/Time...
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
How reset time?
Set the date and time
You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display.
Regards...
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How do i use date in visual basic 6
I am not getting your problem clearly.
If you are referring to save the input dates as date in database with the help of sql query then you need to provide hash(#) mark at the beginning and end of date values. It will resolve your problem.
Hope this helps and let me know if you are not getting the solution clearly.
Thanks.
Mar 06, 2009 | Microsoft Visual Basic 6.0 for PC
How to create a multiple access query and put altogether into 1 SQL Scrip(.sql file)
Suggest using Union Query. Thus, you can add more queries from many table and the output will be in one (1) query. Bear in mind that all fields must have same Field Name.
For example:
tblOne contains dtDate1 fieldname. Your query will select [tblOne].[dtDate1] As myDate.
tblTwo contains dtDate2 fieldname. Your query will have the following SQL:
Select [tblOne].[dtDate1] As myDate
UNION Select [tblTwo].[dtDate2] as myDate
Thus the output will result dates from tblOne and tblTwo in a column called myDate.
Regards,
Maha
Feb 05, 2009 | Microsoft Computers & Internet
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
Nov 20, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Reset time
Nov 05, 2007 | Dymo DateMark Date/Time Stamper
Viewing ms Sql Server database on Access
Are you familiar with "Linking" tables in Access? In Access: File --> Get External Data --> Link Tables. This will bring up a dialog box which allows you to browse to your SQL server and select the table you want.
Aug 23, 2007 | Microsoft SQL Server Standard Edition for...
hth
Aug 14, 2007 | Microsoft Office 2003 Basic Edition...
Microsoft SQL Server 2005 Standard Edition Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
