IGNIS AWV 404/2 WASHING MACHINE, DRUM WILL NOT MOVE UP OR DOWN.How can I get my laundry out?
DOOR MAYBE NOT CLOSED PROPERLY BEFORE STARTING MACHINE-HAVE MANAGED TO DRAIN WATER. MACHINE MAKING A NOISE WHEN WORKING SO TURNED IT OFF, THAT IS WHEN I FOUND I COULD NOT OPEN DOOR.
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
  • 1314 Answers
SOURCE: Front Load Washing machine won't spin, drain or rinse
if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Posted on Jan 18, 2008
aborcass
  • 2651 Answers
SOURCE: Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Posted on Oct 31, 2008
  • 73 Answers
SOURCE: washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
Posted on May 23, 2009
SOURCE: My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Posted on Jun 27, 2009
Machine shows E 61 when switch on.
E61 I think this a door lock error code. When you close, the door it activates a switch which will allow the machine to start a wash programme. Conversely the first thing the selected programme does is activate a solenoid, to stop you opening the door before the machine is ready. Think spinning drums, small children and cats, or flooded floors. I digress, if that little switch stops working or the mechanism has moved slightly and isn't activated, the machine assumes the door is open.
Maybe not a great help but we have narrowed things down.
H
Apr 03, 2016 | Washing Machines
Dishwasher making strange noise
Check the spray arms for clogs..
Mar 30, 2014 | Dishwashers
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Whirlpool DU915PWSSO dishwasher. When door is closed lights work. I can push start and select options, but nothing happens. No noise, no water, nothing. Pushing Cancel/Drain does appear to make the...
try pulling off the bottom spray arm under that plastic cowel is the filter system clean it out . take the cowel off and its very easy to clean the filter if that doesnt work then underneath the dishwasher where the water inlet is there is a valve . it has two outlets one going to the dishwaser and one coming from your water supply . check to make sure u have continuity going thru the valve if its not working replace the valve (word of caution turn off the water when replacing valve ) Also before changing the valve pull off both hoses from the valve there is a filter in each inlet make sure they r clear and not plugged
Oct 03, 2013 | Dishwashers
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
Ge dishwasher about 7 years old as soon as we start it we hear the water turn on to fill but it does not fill water it imeadily start draining
Hello
Water Not Flowing Properly
Check to see if the water source to your dishwasher is turned on and not blocked or clogged. Also make sure the water line between the dishwasher and water source is connected and free from blockage. The door has to be closed properly as well.
If your water pressure is low, you can adjust the water intake value on the dishwasher to allow more water to flow through.
There is an overflow detection device on the dishwasher, so if the machine detected that, it will shut down the intake pump and open the drain pump. If this is the case, you will need to call for service because if there is water in the machine it will have to be cleaned out. Remember to turn off the water source to prevent further damage.
Sep 12, 2011 | Dishwashers
The spin cycle won't engage, the laundry tumbles, it starts to speed up and then slows back down to tumbling. I've removed some of the laundry, set it to rinse and spin and it still does the same thing....
Welcome to FixYa.
Based on what you've described, there are a few possible scenarios that will cause this.
1) It could be either the shipping bolts are still in place, shown below
2) the water hoses are backwards ( it's critical for proper operation to make sure hot goes to hot and cold to cold )
3) or even you're using too much detergent (or the wrong type of detergent), you must use "HE" only in these frontload machines
4) the leveling legs/feet aren't secured proper or are uneven...
...otherwise it doesn't spin the items out very well either due to too much vibration sensed to maximize spin.
Make sure the shipping bolts are out first, i.e.
Level properly, i.e.
And use only detergent with this label, but not much is necessary.
**especially if your laundry has been washed in a top load prior to now since the items will likely still contain soap from the old washing...maybe pre-wash all your items before placing them in a actual wash cycle with detergent for the first time**
i.e.
Let me know what you find and I'll try to help you move forward from here.
Regards,
Macmarkus :)
Mar 12, 2011 | LG WM2487H Front Load Washer
Hi! I have a Maytag Neptune front loading washer machine. On a few occasions I have found a small amount of water in the drum before starting my weekly laundry. Today when I went to start my laundry...
This is symptomatic of a water control valve not closing completely- its no power/fail position is closed.
Whichever it is, hot or cold, needs replacing!
Service call ;-0(
Good luck,
John C
Mar 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
