Question about Samsung Cell Phones
1200 sim problem
INSERT SIM
  • 4 Answers
Teleaner
Posted on Jul 15, 2013
SOURCE: insert correct sim card
i you should try a software update, you can get this from www.sonyericsson.com/support. hope this helps
Posted on Nov 21, 2007
  • 242 Answers
SOURCE: Insert SIM Card
make sure the sim card can make good contact with the phone.
Also check if it doesn't have space to slide, causing it to loose contact with the phone.
Posted on Mar 27, 2008
My phones displays the message Insert SIM Card even though it has the SIM Card.
Posted on May 04, 2008
bdouglas
  • 290 Answers
SOURCE: sim card
Sounds like phone is locked or firmware is bad
Posted on Mar 16, 2009
urbanhookupz
  • 213 Answers
SOURCE: WHY DOES MY PHONE SAYS INSERT SIM
try taking SIM and battery out placing it back in an powering on.
If you try this and it still does not work you may need a new SIM card. Take it to a local dealer they should have a new SIM they will put your number on it and you will be back in business.
If the new SIM doesn't not work you will now know it is your Phone, which means time for a new one.
good luck
Posted on Mar 27, 2010
"NOKIA 1200 SIM CARD NOT REJECTER"
the problem is with your sim card please check that with the sim card service provider...
Feb 03, 2013 | MyNetDeals Nokia 1200 Accessory Bundle -...
Tip
Insert SIM Card Problem Fix
The "Insert SIM Card" problem can be irritating when it keeps on popping up even when a SIM card is actually been inserted into the phone's SIM card holder. It can sometimes be remedied by cleaning both the SIM card and the holder terminals with a cotton swab immersed in alcohol; most preferably 70% alcohol solution. Sometimes the holder is not tightly holding the SIM card causing the problem. This can be solved by padding up the back of the SIM card with a small sheet paper or any appropriate material enough for the holder to hold the SIM card tightly. Another way to fix the problem is by bending in the mid-section of the SIM holder cover.
Nokia 1110, 1110i, 1200, 1028, 1209 and all other member of the family of Nokia phones with USB ports similar to the ones mentioned earlier have the tendencies to experience the "Insert SIM Card" problem not due to a dirty terminals nor a loose holder but due to dirty, soiled, or oxidized USB port terminals. The fix is just as simple as cleaning the USB port terminals but make sure to remove the phone battery prior to the cleaning. Use a paper clip, a safety pin, or a needle with bended tip to scrape off the dirt between the port terminals and dip it in alcohol to wash it out.
The cleaning can be done without the necessity of disassembling the phone but if proper tools are available, disassemble the phone to clean the inside of the system connector, the one where the USB port, the charging socket, and the headset socket are located.
System Connector
People may wonder how a dirty USB port can lead to the "Insert SIM Card" issue and guess what; it is not even included in the Nokia Service Manual. The fix was discovered accidentally and proven many times that a dirty USB port is indeed the source of the problem.
on Apr 09, 2010 | Cell Phones
Nokia 1200 insert sim
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Sep 21, 2012 | Nokia 1100 1101 1108 1110 1112 1200 1208...
Sony ericson t303 insert sim
Hi the sim contacts in the phone try praising them up a little
Dec 21, 2011 | Sony Ericsson Cell Phones
When i insert sim to nokia 1650,the mobile hanging on display swoed only NOKIA
Phone of nokia like 1200 1208 1209 1650 sim ic location is same, you should try this jumperS IN R2700 to solve your problem....!!!!!!!!!!
Jul 16, 2011 | Computers & Internet
Every time my nokia 1200 shows" insert sim "even if there is a sim.Is that a software problem .how can i get rid of that. Please help me..........
It may be due to network lock,
you can unlock it and switch over to another network , you can get unlock codes here http://www.superunlockcodes.com/nokia-1200/rs12wp9/
you need to specify the country and network provider
Oct 18, 2010 | Nokia 1100
Samsung Geino, my sim is inserted but my phones keeps saying insert sim i carnt phone anyone blah blah help
Hi,when a phone keeps saying insert Sim card, is either the Sim card has problem or the Sim tray of the phone is bad and will need tobe replaced.
To confirm, Take the Sim card and insert it into another phone, If it still says insert Sim, that means the Sim card is bad, But if the Sim card works with another phone, That means the Sim tray of the phone is damaged.
Sim tray is located on the phone where you insert your Sim card in on the phone to make sure the Sim works with the phone.
Have a nice day.
Sep 12, 2010 | Cell Phones
Phone locked
d 1200 tata haier mobile phone lock please solve the problem
Sep 19, 2008 | Samsung SGH-U600
Cell Phones Logo
23 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
