Question about Microwave Ovens
Gold line microwave
How to store memory or Preset settings
How do i set clock on Dunelm cream microwave mod no52753
So just to make sure that it wasnt an easy fix, I went to the Dunelm site to see if they had a manual. No such luck.
I did however see that on the front of this microwave (the cream one), there are 6 buttons near the top. One of them is the Preset/clock button.
What I have known with most (not all) is that with the clock feature, you press the clock, set it and press clock once more.
HOWEVER
With this model because clock is the SECOND item listed, I suggest to press that button twice, wait for the clock to come up 00:00 and set it using the same button (preset option).
Unfortunately I don't know this for certain as I am only using an educated deduction on other brands of microwaves with similar front panels.
I really hope this helps, please let me know if it works as I will be contacting Dunelm to ask for a pdf manual.
Jul 21, 2016 | Microwave Ovens
I need some operating help
First off we need Make and Model
Then we can help you. You also need to tell us what you want to know.
Microwave ovens are pretty simple, you put the food and set a preset time, then you press start.
Dec 28, 2015 | Microwave Ovens
How do I set the clock
On some Galanz models setting the clock is a bit unusual.
You have to press the clock/preset button once then press pause/clear. Now it is in Clock mode setting and you can set the hour then press clock/preset again to set the minutes then press once more clock/prest to finish the operation.
Mar 27, 2013 | Microwave Ovens
Hello, I have an AEG microwave, 6 years old. When I turn the button to chose the cookingtime and the WATT , the display shows what I choosed so thats OK. When i then press the start button the microwave...
This can be due to wrong choice or fault in the power supply ,main board or the magnetron.
You should try with a preset selection and if the microwave works then the fault relates to correcting the power to time settings.
Check out with microwave cooking tips.
Feb 01, 2013 | AEG MC143EUX 750 Watts Microwave Oven
How do you defrost on the microwave
What is need to set the program, select defrost function then select the weight of the food to be defrosted and push the value of the weight. Now select the heat value and press start as the processor will then decide the time to defrost.
This is a simple program setting or else you can choose a preset heating defroster program.
Aug 19, 2011 | Microwave Ovens
My gold star microwave worked lastnight. Went to
The outside bottom of your microwave usually has a belt hidden underneath a small cover directly under the turntable. This belt sometimes falls off or breaks, and sometimes the motor that turns the belt fails. Most time the motor can be found if you remove the main top cover of the microwave, about 10 screws.
Parts can be easily found at your local appliance parts store.
Best of luck.
Jan 20, 2010 | Goldstar Microwave Ovens
Whirlpool gold GH7155XHS
replace thermal fuse in line with the power cord. Open cover, follow power cord to a small cylinder about 3 milimeters across. It is pointed on one end. Cut it out and take to an appliance repair store. solder the replacement thermal fuse back in.
Sep 15, 2008 | Microwave Ovens
Maytag microwwave oven
check the magnitron and capacitors one of this bad
Sep 18, 2007 | Kenmore 80412 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
